Old 01-16-2014, 10:30 AM   #1
ifightfire
ifightfire's Avatar
Default Main bearing/babit help
ive dissembled my Model A engine. sad to fine it in worse shape than i thought i would fine. here are a few pics of the rear bearing area. whats your opinion on what is my best repair options now?
ifightfire is offline   Reply With Quote
Old 01-16-2014, 10:33 AM   #2
V4F
V4F's Avatar
Default Re: Main bearing/babit help
it appears as tho the Babbitt is coming apart . how many miles ? if the rear is like that , what does the center look like ? I think rebuilding is next ........
V4f
V4F is offline   Reply With Quote
Old 01-16-2014, 12:20 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
What was the reason for taking the engine apart?
Was it just to check things out, or was there a specific problem?
Old 01-16-2014, 12:38 PM   #4
ifightfire
ifightfire's Avatar
just checking things out i have never had the engine running. i was hoping to dissemble and clean and reassemble but now im not sure what to do.
Old 01-16-2014, 02:39 PM   #5
Dave in MN
Dave in MN's Avatar
I see you still have some shims in the rear bearing. IMO: If you are just going to drive it a few times each summer, you could probably put it back together adjusting the clearances as you do and it would likely last a couple to many years if you keep the RPM's down. I suggest you study the rest of the components to see if they are worthy of reassembly or need attention. (As commented above...what condition is the center main in?)
Good Day!
Dave in MN is offline   Reply With Quote
Old 01-16-2014, 02:41 PM   #6
Mark in MT
The first consideration is if the crankshaft is usable in its present condition. If the journals are not all smooth and perfectly round, then it needs to be reground. The cost of getting a crank ground is a lot less than a new babbitt job, and a bad crank will soon destroy the best babbitt there is.
Mark in MT
Always looking for another opportunity to be wrong.
Mark in MT is offline   Reply With Quote
Old 01-16-2014, 02:45 PM   #7
Patrick L.
Patrick L.'s Avatar
Maybe I'm missing something, but, I'm with Dave.
Old 01-16-2014, 03:11 PM   #8
ifightfire
ifightfire's Avatar
ok im feeling a little better now. i was thinking i was headed for $$$$ with no other options. the center main bearings are much better than the rear bearing.yes i will only be driving limited amouts
Old 01-16-2014, 03:53 PM   #9
Tom Wesenberg
I also agree with Dave. Chances are the babbit in my temporary Phaeton engine looks worse than your's, and I'm still driving it.
Old 01-16-2014, 06:21 PM   #10
James Rogers
James Rogers's Avatar
And if you have the crank reground, you will for sure need to have the babbitt redone!
James Rogers is offline   Reply With Quote
Old 01-16-2014, 09:26 PM   #11
bdave_mcc
bdave_mcc's Avatar
Im not an expert by any means. I had a similar thread a few weeks ago. The babbit on the rear main was cracked like yours except it was on the cap...and it was missing the oil drain tube, so i had a severe oil leak AND damaged babbit....scared the crap out of me. I took the advice of James and adjusted the clearance on the mains using the foil method and put it back together. So far so good, and no oil leak.
bdave_mcc is offline   Reply With Quote
Old 01-17-2014, 08:29 AM   #12
30ccpickup
30ccpickup's Avatar
Here is the link.
http://www.fordbarn.com/forum/showthread.php?t=126563
Paul
http://MODELABASICS.com/ How Things Work on a Model "A" Ford
Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles.
30ccpickup is offline   Reply With Quote
Old 01-17-2014, 08:38 AM   #13
BrianBurkert
BrianBurkert's Avatar
After refurbishing two marginal engines and driving them for years (a couple thousand miles) I can also say that if you can get the proper clearance, you are probably OK. This is especially true if you're not planning on any long distance interstate tours.
My patch together engines have actually laster longer than one that I had "professionally" rebuilt.
BrianBurkert is offline   Reply With Quote
