Old 10-08-2013, 10:41 AM   #1
Jim Kroeger
Default Where to get black touch up paint?
There has been a lot of discussion about how to paint a Model A but does one know where to get black touch up paint? I own a 1930 Town Sedan and on a tour a fellow club member bumped my front fender and took some paint off. No need to repaint the whole fender, just touch it up a bit. I assume most A's fenders are painted semi-gloss black. Is this the case? Does anyone know where to purchase the proper color black touch up paint? Thanks. JIM
Jim Kroeger is offline   Reply With Quote
Old 10-08-2013, 10:44 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Where to get black touch up paint?
Jim, there is probably more varieties of a Black shade than any other color. My suggestion is to take the vehicle to a reputable paint jobber who has the capability to match what you presently have into a ½-pint quantity. He can also give you a paint formula that you can use at a later date.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 10-08-2013, 10:45 AM   #3
redmodelt
redmodelt's Avatar
Your best bet is to take it someplace that can scan the color and get a close match. The paint would have been gloss black but depending on the age may have faded some and may now looks like semi-gloss.
Old 10-08-2013, 02:09 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Jimbo, Dog heere, Jist go to a paint store & ask fur "BUSTER BLACK" kolor Buster T.
"THE ASSISTANT GURU OF STUFF"
Old 10-08-2013, 02:46 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
Black nail polish, do not use testors as it dries a dark gray.
Old 10-08-2013, 02:53 PM   #6
Duffy1
I touch up my black fenders with Dupli-Color NG CC 427 purchased at Auto Zone . Works great.
Duffy1 is offline   Reply With Quote
Old 10-09-2013, 02:47 AM   #7
Jim Kroeger
Thanks for the suggestion. I will head to Auto Zone.
Old 10-09-2013, 06:20 AM   #8
Ross/Kzoo
Ross/Kzoo's Avatar
As Brent said there very many shades of black. After you go to Auto Zone and touch up your paint. Then check it after it's dried in the sun light. If it suits your needs fine, if not then do as Brent said.
Ross/Kzoo is offline   Reply With Quote
Old 10-09-2013, 07:42 AM   #9
Logan
Logan's Avatar
Brush touching black is easy, and you can make it almost disappear, as long as there isn't major damage other than a scratch. Get some black, probably semi gloss, or gloss. Then start slowly building it up. Add one coat then wait about 15 minutes and maybe go back and add another coat with your brush. Then let it dry. At this point you'll probably need to scuff with 2000 grit wet, and knock down the edges. Go back and add one last coat. Let it dry. Then wet sand with 2000 again, and them buff and polish the area. The scratch will almost disappear. With black, you'll see a little ring around where the scratch use to be that you won't be able to make go away but it's better than the scratch. My boss bought a Tudor a couple months ago, and it had a nasty scratch on the front fender. One that would make you want to repaint it. This is what we did to it, and it disappeared for the most part. Definetly looked better than before
Cowtown A's
Logan is offline   Reply With Quote
Old 10-09-2013, 10:53 AM   #10
azmodela
Follow Brent's suggestions here! There are a lot of variables, single stage, two stage, lacquer, enamel, urethane, is it the "blue" black or the "brown" black?
That is, unless you want it to look like a 20/20 job. Done in under 20 minutes for less than $20.
azmodela is offline   Reply With Quote
Old 10-09-2013, 11:25 AM   #11
Fred K-OR
Fred K-OR's Avatar
A lot of good suggestions above. But it depends on what you want and how good of job you want to have on your car. So you decide.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
