Old 06-16-2013, 02:29 PM   #21
Fred K-OR
Fred K-OR's Avatar
Default Re: Timing?????!!!!!
If all else fails, here is a solution. I being a simple minded individual and not an expert in this area, use the simpleton approach. It works for me. Once you use this thing, you can then "tweak" it a bit like mentioned in these posts to get it just right.
http://www.brattons.com/uploads/imag...arge/17502.jpg
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 06-16-2013, 02:32 PM   #22
SDJason
SDJason's Avatar
Actually used one of these the last time I set my timing - worked great, and pretty simple to use. Everyone should own a cam wrench anyways, so why not have one that'll pull double duty?
SDJason is offline   Reply With Quote
Old 06-16-2013, 03:08 PM   #23
TDO
TDO's Avatar
I also use a 6volt bulb with alligator clips to take out back lash . works great for me.
TDO is offline   Reply With Quote
Old 06-16-2013, 03:13 PM   #24
Doot
Doot's Avatar
It runs great!
That's what it was....The wording of the "opposite" number 1 lobe.....
If I would have not turned the rotor 180 degrees, It would've been fine all along!!!!!
Live and learn! THANK YOU again!!!!!!
Doot is offline   Reply With Quote
Old 06-16-2013, 03:14 PM   #25
Doot
Doot's Avatar
Thanks to all Happy Father's Day!!!!
Old 06-16-2013, 07:34 PM   #26
glenn in camino
glenn in camino's Avatar
Did you retard the spark first?
Old 06-16-2013, 08:54 PM   #27
James Rogers
James Rogers's Avatar
Why is timing a Model A with a stock distributor so complicated? I find I can usually time one faster than most people can get out their fancy tools and be spot on at that.
James Rogers is offline   Reply With Quote
Old 06-16-2013, 08:55 PM   #28
ctvpa
ctvpa's Avatar
Here it is for you https://www.youtube.com/watch?v=3Xc7r0djEKo
and https://www.youtube.com/watch?v=zju4nagtiCU
ctvpa is offline   Reply With Quote
Old 06-17-2013, 05:12 PM   #29
broommaker
Just a note, I was looking through Snyder's catalog and run across a dist. cam wrench, which I needed one, ordered the one with the instructions on the handle, it's a NUR-REX, I tried it, worked the first, great little tool to carry in the "A".....
Jim Norris
broommaker is offline   Reply With Quote
Old 06-17-2013, 05:55 PM   #30
1931 flamingo
1931 flamingo's Avatar
I recommended this to everyone when I first saw it in the catalog. FWIW
Paul in CT
Old 06-17-2013, 06:31 PM   #31
bhiland
Once you get it right u can do it evrrytime. The first time is the trick.
bhiland is offline   Reply With Quote
Old 06-17-2013, 07:21 PM   #32
Purdy Swoft
Purdy Swoft's Avatar
Model A's have got to be one of the easiest automobiles to time. Its difficult to explain how its done so that it is understandable by a person that has never set the timing on a model A.
Old 06-18-2013, 07:11 AM   #33
Richard Wilson
Richard Wilson's Avatar
I like to use my little electrical test meter to do the same. Both tools work great and should be part of any Model A tool box.
Richard Wilson is offline   Reply With Quote
Old 06-18-2013, 03:43 PM   #34
Doot
Doot's Avatar
You are exactly right!
I've gone through the motions a dozen times during this minor set-back, but once I made sense of the manual's wording, & actually got it in time...well, hell now I'm almost a pro! You can bet that I will not forget how to set the timing on this car any time soon!!!!
