Old 05-06-2013, 12:06 PM   #1
old46ford
Default Shock absorbers - 1946 Coupe
How do the original shock absorbers work and do they go bad? What's inside them? Maintenance?
old46ford is offline   Reply With Quote
Old 05-06-2013, 12:35 PM   #2
Vic Piano
Vic Piano's Avatar
Default Re: Shock absorbers - 1946 Coupe
That's a question for Bill Wzorek (he is on the FordBarn), I'm sure he'll have a shocking answer for you.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 02-02-2025, 01:11 PM   #3
Rangerstan
Disregard, just posting on an old post so I can get my newbie 9 posts so I can contact a member, never heard of probation for a forum
Rangerstan is offline   Reply With Quote
Old 02-02-2025, 02:12 PM   #4
51woodie
51woodie's Avatar
The attached will give the info you are asking about. Yes, they can "go bad". If they are not leaking at the pivot shaft seal, and there is good resistance in the arm movement with the shock link disconnected, that could be considered as "good".
51woodie is offline   Reply With Quote
