Old 02-04-2013, 02:35 PM   #1
JoeWay
JoeWay's Avatar
Default Stud Welder
The topic of stud welders comes up here fairly often. ToolTopia just sent out their latest email flyer, and it offers what looks like a good one at a large discount from regular pricing. See this link for more information.
Joe
1929 Tudor
since 1962
Feather River A's
JoeWay is offline   Reply With Quote
Old 02-04-2013, 04:41 PM   #2
ford3
Default Re: Stud Welder
thats a lot of money for a tool that the home restorer wont use that often, harbor frieght sells one for less than a $100 and it works real goog, i have used one and it does the job well, if your a shop the $400 one is probably what you need
ford3 is offline   Reply With Quote
Old 02-04-2013, 05:12 PM   #3
Fred K-OR
Fred K-OR's Avatar
Here is the guy again that knows nothing about this sort of thing. What do you use a "stud" welder for? Not trying to be "smart" I just don't know and have never used anything like this.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 02-04-2013, 05:34 PM   #4
Mike V. Florida
Mike V. Florida's Avatar
Two things actually, the stud is welded to the inside of a dent and then the puller is used to pull the dent out. The unit can also be used to heat an area to cause it to shrink.
Old 02-04-2013, 05:54 PM   #5
ford3
using the stud welder means you dont have to drill holes in the metal and insert a sheet metal screw in the hole to pull out the dent with the slide hammer, no holes, no welding them shut, a piece of advice of advice on using the stud welder, use a big pair of wire cutters to remove the studs, grip the head of the stud and twist back and forth to remove it, all that will be left will be a small bit of metal that can easily be sanded off, try not to use the slide hammer to bang the dent out, try pulling on the stud with it, most of the time the dent will come out and not leave a pucker( high top pucker) if you cant pull it out that way then use the slide hammer tool to bang it out
Old 02-04-2013, 07:00 PM   #6
Popeye31
Popeye31's Avatar
I had a mac tools stud welder for 10 years cost me $400 when it went out I went to harber freight and bought theres I see no difference in the operation between the two. I was told by a coworker that did some reserch on these and he said there are only 3 companies that make these and everyone just puts there name on it.
Live your dreams
Popeye31 is offline   Reply With Quote
Old 02-04-2013, 08:01 PM   #7
Fred K-OR
Fred K-OR's Avatar
Thanks guys. Learn something new every day.
Fred Kroon
1929 Std Coupe
1929 Huckster
Old 02-04-2013, 10:41 PM   #8
Jazzjr
Jazzjr's Avatar
Fred and others who don't know what a Stud gun is, click on the link below and read the Description Paragraph. I also use it to fill holes that someone has drilled in the body, and Shrink Dents.
Again the Harbor Freight Tools come up again, but for my Pocket Book, and how much I use it, The HF Gun works for Me.
http://www.harborfreight.com/stud-we...kit-98357.html
Jazzjr is offline   Reply With Quote
Old 02-05-2013, 10:49 PM   #9
Doug in NJ
Doug in NJ's Avatar
I got a HF model a few years ago for about $109.95, and it was money well spent.
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 02-06-2013, 06:13 AM   #10
Ross/Kzoo
Ross/Kzoo's Avatar
Doug
It's a better deal now @ $99.99 plus you could use a 20% discount coupon.
Ross/Kzoo is offline   Reply With Quote
Old 02-06-2013, 06:33 AM   #11
Kevin in NJ
Stud welder s can also be used to remove nails.
Old 02-06-2013, 08:29 AM   #12
BudP
BudP's Avatar
Here is an informative video: https://www.youtube.com/watch?v=chWbjNmVs58
BudP is offline   Reply With Quote
Old 02-06-2013, 04:25 PM   #13
ford3
lol, that instructor needs a little more training on the use of the stud gun, you dont cut the nail off and the head welded to the metal, you take the wire cutters, side cutters, or dykes, whatever you call them, grab the head of the nail and twist back and forth and the nail will pop off and not leave a piece welded to the metal which will need to be ground off
