Old 02-01-2013, 02:52 PM   #1
stush
Default 1940 standard grill
How can I tell if my grill is repop or original Ford? Think might be repop but want to make sure.
stush is offline   Reply With Quote
Old 02-01-2013, 03:18 PM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: 1940 standard grill
I am not 100% certain about a '40 Ford V8 (aka Standard) grille but I am certain the '40 DeLuxe grilles had a date on the very bottom. It is small, perhaps less than 1/8" tall but it's there.
I am only guessing here but Drake is very fond of putting his name all over everything he makes so I look for that on a repop.
Or, he's always saying how helpful his staff is, call them and ask...
Old 02-01-2013, 03:22 PM   #3
stush
Thanks grill I bought came in Drake boxes not sure if it is Drake or they put old grill on boxes when new one came in. Need to dig out and look so know what it is before selling it.
Old 02-01-2013, 05:41 PM   #4
joel
joel's Avatar
If it's a drake repop from the 80s, it's hard to tell. If I remember correctly, the only difference was the ejector pins form the mold and that was slight. The present ones are easy; they say Drake on them. I don't know when that started. Hre is a pic of an original
joel is offline   Reply With Quote
Old 02-02-2013, 09:38 PM   #5
Lincoln
Original Grilles were of a Diecast material and probably had the Part Number cast into it on the backside. All the NOS Service Relacement grilles I have seen have had these numbers. Repros would not have these numbers.
Lincoln is offline   Reply With Quote
Old 02-03-2013, 06:17 PM   #6
stush
Well looks like the grill is original or atleast the sides. There is Ford part number stamped on each side, one side is 01A-8207A1 LH*. Did not find anything on center sections though.
Old 02-03-2013, 07:20 PM   #7
Kube
Super Moderator
Kube's Avatar
Stamped? Or cast upon?
Is that "LH" on there?
Old 02-03-2013, 07:22 PM   #8
stush
The LH is there and it is cast not stamped.
Old 02-05-2013, 10:39 AM   #9
deuce_roadster
deuce_roadster's Avatar
I have a couple of known NOS V8 grilles that have never been assembled that were purchased long before Bob Drake started having them cast. I will look at them and take some pictures in the next few days unless Kube does this first. It would surprise me if LH or RH was cast along with the part # but could be.
Old 02-05-2013, 02:38 PM   #10
Kube
Super Moderator
Kube's Avatar
Deuce, Like you, I was very suspicious of the LH / RH. Why would Ford bother with such? The part number quickly identifies the part. Also, I have never witnessed any Ford OEM part marked RH /LF
It took me a bit to gather up my spare grilles. I have both a left & right NOS as well as three used rights and two used lefts. NONE have any RH nor LH.
I am confident that any grille with these markings is a reproduction.
Old 02-05-2013, 03:23 PM   #11
stush
Here is pic of the casting for the part number.
Old 02-05-2013, 03:52 PM   #12
Russco
Russco's Avatar
Sorry to hijack but I am in need of a nice standard grille I assume the drake repops are pretty nice?
Life is hard, after all it kills you!
Russco is offline   Reply With Quote
Old 02-05-2013, 05:54 PM   #13
stush
So would Drake have cast the Ford part number or did someone else reproduce these?
Old 02-05-2013, 06:57 PM   #14
V8COOPMAN
V8COOPMAN's Avatar
Might be one of Gene Scott's early creations. DD
Click Links Below __
T5 W/TORQUE TUBE
