Old 01-22-2013, 12:33 PM   #1
Car Pit
Car Pit's Avatar
Default Running boards
As I look through online catalogs on running boards, it appears that replacement running boards are separate pieces from the splash apron.
The running board and splash apron on my car are formed from a single sheet. Were the the originals separate parts or one piece?
Car Pit is offline   Reply With Quote
Old 01-22-2013, 12:35 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Running boards
That is likely because your model year is 1930. Body Aprons and Running boards can be obtained in reproduction with the one-piece body apron and the two-piece body apron (likely what you have). You can verify this by looking at the running board where it attaches to the front fender and see if there is a dividing line on the body apron there.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 01-22-2013, 12:39 PM   #3
lance leblanc
lance leblanc's Avatar
Originals were two pieces
lance leblanc is offline   Reply With Quote
Old 01-22-2013, 12:41 PM   #4
ctlikon0712
ctlikon0712's Avatar
I'm confused, I think I read the statement differently than Brent. Car Pit, are you saying that your running board and splash aprons are all one piece together/no bolts, or that the splash apron is one piece instead of two?
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
Old 01-22-2013, 12:58 PM   #5
Car Pit
Car Pit's Avatar
The apron and the running board are one piece. The attached photo is the best I have to show.
Old 01-22-2013, 01:26 PM   #6
Car Pit
Car Pit's Avatar
And to Brent's point, there is a dividing line in the apron at the seem of the front fender. So, one section of the apron is formed with the running board.
Old 01-22-2013, 01:30 PM   #7
ctlikon0712
If you crawl up under the running board there will be a flange where the board and apron are flanged together. Not one piece. The two piece apron and the running board make 3 separate pieces.
Old 01-22-2013, 01:47 PM   #8
Randy in ca
Randy in ca's Avatar
All the major suppliers (Bratton's, Snyder's, etc.) sell the 1930 running boards with the splash apron attached to it.
Randy in ca is offline   Reply With Quote
Old 01-22-2013, 02:22 PM   #9
ctlikon0712
Wow, Randy you are correct, they(I checked online) sell the 30's with or without the running board spotwelded on. I like it when I learn sumtin!
Old 01-22-2013, 09:11 PM   #10
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
CT,
Today I learned that I'm s'posed to turn off the oxygen valve FIRST after welding!! GEEZ! I'm gonna' miss that "POP"!!!!! Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 01-22-2013, 09:17 PM   #11
Mitch//pa
Originally Posted by BILL WILLIAMSON View Post
CT,
turn off the oxygen last as it cleans the tip.
Old 01-22-2013, 09:19 PM   #12
Mikeinnj
Mikeinnj's Avatar
CT,
Bill, Is there a reason that you always have to hijack a thread ? I don't get you at all..
Mikeinnj is offline   Reply With Quote
Old 01-23-2013, 12:20 AM   #13
BILL WILLIAMSON
Why you so kranky, Mike,
I also contribute a damn lot of good proven advice & helps-------------Bill W. By the way, I didn't "hijack" the thread, I was commenting on another poster saying he learned something NEW today!
Old 01-22-2013, 10:03 PM   #14
Tom Wesenberg
Tom Wesenberg's Avatar
CT,
I always turn off the acetylene first so I don't get a room full of soot.
Old 01-23-2013, 12:31 AM   #15
BILL WILLIAMSON
Mitch & Tom,
I read in the genuine VICTOR welding manual that turning the gas off first usually causes a pop that can back up soot & carbon in the mixing chambers & is tough on the large & the small "O" rings where the tip or the cutting head seals to the mixing body. (Buster just said, "SO THERE!) If it makes you feel better, I've always done it BASSACKWARDS in my mixed & colorful past. Gotta' read more! LOL Bill W.
Old 01-23-2013, 12:32 AM   #16
dumb person
dumb person's Avatar
CT,
Not trying to hijack the thread or anything but i was always told the bottle would explode if you turned off the oxygen last. Not that anyone can afford to weld with gas these days with bottle hire costing more than the gas.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 01-22-2013, 02:22 PM   #17
BRENT in 10-uh-C
I think there is some confusion in this. Yes, the majority of the 1930's had a body apron that WAS attached to the running board. It was one-piece. The corresponding fender originally had a short apron that was spot welded onto the fender flange making it one-piece too. Below are some pictures from different projects that hopefully will make this more clear.
BRENT in 10-uh-C
Old 01-23-2013, 11:12 AM   #18
Marco Tahtaras
Marco Tahtaras's Avatar
I never would have expected a question about running boards would lead to seven posts about someone having gas.
Yes, 1930 passenger models had running boards formed integral with the main body of the running board shield until late September 1930. These have never been reproduced. Replacements made of two pieces are available. I hope they are better than the ones made 30 years ago as those were quite bad dimensionally.
The one in your photo appears very restorable. That would certainly be my choice.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 01-23-2013, 11:27 AM   #19
lance leblanc
So I just learnt sumtin new to.
Was '30 the only year that this was done.
Old 01-23-2013, 01:21 PM   #20
Car Pit
Car Pit's Avatar
Yes, my intent is to work with what I have, especially if it is original. I ask because there are other signs of mismatched parts on the car that I randomly learn about, like the headlight bar is for a '29, not a '30.
