The Ford Barn
-   -   Running boards (https://www.fordbarn.com/forum/showthread.php?t=95358)
Car Pit 01-22-2013 12:33 PM
Running boards
As I look through online catalogs on running boards, it appears that replacement running boards are separate pieces from the splash apron.
The running board and splash apron on my car are formed from a single sheet. Were the the originals separate parts or one piece?
BRENT in 10-uh-C 01-22-2013 12:35 PM
Re: Running boards
That is likely because your model year is 1930. Body Aprons and Running boards can be obtained in reproduction with the one-piece body apron and the two-piece body apron (likely what you have). You can verify this by looking at the running board where it attaches to the front fender and see if there is a dividing line on the body apron there.
lance leblanc 01-22-2013 12:39 PM
Re: Running boards
Originals were two pieces
ctlikon0712 01-22-2013 12:41 PM
Re: Running boards
I'm confused, I think I read the statement differently than Brent. Car Pit, are you saying that your running board and splash aprons are all one piece together/no bolts, or that the splash apron is one piece instead of two?
Car Pit 01-22-2013 12:58 PM
Re: Running boards
1 Attachment(s)
The apron and the running board are one piece. The attached photo is the best I have to show.
Car Pit 01-22-2013 01:26 PM
Re: Running boards
And to Brent's point, there is a dividing line in the apron at the seem of the front fender. So, one section of the apron is formed with the running board.
ctlikon0712 01-22-2013 01:30 PM
Re: Running boards
If you crawl up under the running board there will be a flange where the board and apron are flanged together. Not one piece. The two piece apron and the running board make 3 separate pieces.
Randy in ca 01-22-2013 01:47 PM
Re: Running boards
All the major suppliers (Bratton's, Snyder's, etc.) sell the 1930 running boards with the splash apron attached to it.
ctlikon0712 01-22-2013 02:22 PM
Re: Running boards
Wow, Randy you are correct, they(I checked online) sell the 30's with or without the running board spotwelded on. I like it when I learn sumtin! :)
BRENT in 10-uh-C 01-22-2013 02:22 PM
Re: Running boards
4 Attachment(s)
I think there is some confusion in this. Yes, the majority of the 1930's had a body apron that WAS attached to the running board. It was one-piece. The corresponding fender originally had a short apron that was spot welded onto the fender flange making it one-piece too. Below are some pictures from different projects that hopefully will make this more clear.
BILL WILLIAMSON 01-22-2013 09:11 PM
Re: Running boards
CT,
Today I learned that I'm s'posed to turn off the oxygen valve FIRST after welding!! GEEZ! I'm gonna' miss that "POP"!!!!!:eek: Bill W.
Mitch//pa 01-22-2013 09:17 PM
Re: Running boards
Originally Posted by BILL WILLIAMSON (Post 576651)
CT,
turn off the oxygen last as it cleans the tip.
Mikeinnj 01-22-2013 09:19 PM
Re: Running boards
CT,
Bill, Is there a reason that you always have to hijack a thread ? I don't get you at all..
Tom Wesenberg 01-22-2013 10:03 PM
Re: Running boards
CT,
I always turn off the acetylene first so I don't get a room full of soot.:eek:
BILL WILLIAMSON 01-23-2013 12:20 AM
Re: Running boards
Why you so kranky, Mike,
I also contribute a damn lot of good proven advice & helps-------------Bill W. By the way, I didn't "hijack" the thread, I was commenting on another poster saying he learned something NEW today!
BILL WILLIAMSON 01-23-2013 12:31 AM
Re: Running boards
Mitch & Tom,
I read in the genuine VICTOR welding manual that turning the gas off first usually causes a pop that can back up soot & carbon in the mixing chambers & is tough on the large & the small "O" rings where the tip or the cutting head seals to the mixing body. (Buster just said, "SO THERE!) If it makes you feel better, I've always done it BASSACKWARDS in my mixed & colorful past. Gotta' read more! LOL Bill W.
dumb person 01-23-2013 12:32 AM
Re: Running boards
CT,
Not trying to hijack the thread or anything but i was always told the bottle would explode if you turned off the oxygen last. Not that anyone can afford to weld with gas these days with bottle hire costing more than the gas.
Marco Tahtaras 01-23-2013 11:12 AM
Re: Running boards
I never would have expected a question about running boards would lead to seven posts about someone having gas.
Yes, 1930 passenger models had running boards formed integral with the main body of the running board shield until late September 1930. These have never been reproduced. Replacements made of two pieces are available. I hope they are better than the ones made 30 years ago as those were quite bad dimensionally.
The one in your photo appears very restorable. That would certainly be my choice.
http://abarnyard.com/temp/chassis/run_board_bottom.jpg
lance leblanc 01-23-2013 11:27 AM
Re: Running boards
So I just learnt sumtin new to.
Was '30 the only year that this was done.
Car Pit 01-23-2013 01:21 PM
Re: Running boards
Yes, my intent is to work with what I have, especially if it is original. I ask because there are other signs of mismatched parts on the car that I randomly learn about, like the headlight bar is for a '29, not a '30.
