Old 07-20-2012, 01:16 PM   #21
0rg0
0rg0's Avatar
Default Re: Choke rod question.
So I would assume it's sticking out too far inside the cab ?
0rg0 is offline   Reply With Quote
Old 07-20-2012, 01:35 PM   #22
Tom Wesenberg
Tom Wesenberg's Avatar
Originally Posted by Bob C View Post
Here is a picture from RockHillWill's web site.
Bob
I'm surprized to see how far down into the groove the belt is on the fan. I hope the pulley isn't broken at the spot welds. I bought a fan at a swap meet once where the spot welds had come apart on the pulley.
Old 07-20-2012, 01:36 PM   #23
Brentwood Bob
there are also several lengths to the choke rod. bob
Brentwood Bob is offline   Reply With Quote
Old 07-20-2012, 06:03 PM   #24
Napa Skip
Napa Skip's Avatar
"So I would assume it's sticking out too far inside the cab ?"
It's sometimes difficult to judge based on the angle at which the photo was taken, but it appears to be further into the cab than that on my 1930 coupe (see photo below, although - again - the angle isn't the greatest) - perhaps by the length of a choke driver (cheap shot).
Also, as pointed out by Brentwood Bob above, there are [at least] two different rod lengths; 26" for 1928-29 and 28-1/2" for 1930-31, although it doesn't appear that you have the shorter choke rod.
Skip Keyser
Napa Valley A's
Olympic Vintage Auto Club (1980-1982)
MARC of San Diego (1977-1978)
MAFCA (since 1978)
MARC (since 1977)
Model A owners belong in their Model A’s; Model A’s belong on the road.
Napa Skip is offline   Reply With Quote
Old 07-20-2012, 07:59 PM   #25
peters180a/170b
peters180a/170b's Avatar
Napa skip , The pin on the second needle driver is correct for 1928 to sept.,1930 ..It is not pinned to the choke rod.
peters180a/170b is offline   Reply With Quote
Old 07-20-2012, 08:52 PM   #26
Napa Skip
Napa Skip's Avatar
"...pin...is correct for 1928 to sept., 1930..."
Which - had I bothered to look at the illustration on page 1-11 Revised 2011 of the Model A Judging Standards - I should have known. Thanks for the correction.
Skip Keyser
Napa Valley A's
MAFCA (since 1978)
MARC (since 1977)
Old 07-13-2014, 02:20 AM   #27
Harley03joe
Harley03joe's Avatar
Smile Re: Choke rod question.
Originally Posted by 0rg0 View Post
I have all that stuff, but can't for the life of me figure out how to connect the choke rod to the needle driver ? I could come up with something to make it work, but would like to do it the proper way.
Found This On Youtube
Model A Ford Choke Rod Grommet Replacement - YouTube
Click here: Model A Ford Choke Rod Grommet Replacement - YouTube
Harley03joe is offline   Reply With Quote
