Old 06-08-2012, 06:44 PM   #21
Henry/Kokomo
Henry/Kokomo's Avatar
Default Re: 37 Flathead V8 bike project
If you take off "enthusiastically", does the bike tend to lean account engine torque? Intriguing piece of machinery. I'm impressed.
Henry/Kokomo is offline   Reply With Quote
Old 06-08-2012, 06:59 PM   #22
Boscobill
Boscobill's Avatar
The bike handles and steers really nice, somewhere between a superglide and a goldwing,
There is a bit of torque reaction, but it is mild and does not make the bike go off course or feel a bit unsteady, in fact it's kind of a cool sensation. The flathead is soooo smooth
running and quiet (even with the straight pipes) that it almost feels like an electric motor.
My other bikes are starting to feel jealous and lonely......
Boscobill is offline   Reply With Quote
Old 06-08-2012, 07:09 PM   #23
39portlander
39portlander's Avatar
I rode an electraglide for years, I'm thinking of riding again.
That is a nice ride. Scott
39portlander is offline   Reply With Quote
Old 06-08-2012, 07:42 PM   #24
flat-v8
flat-v8's Avatar
It takes a smart guy to figure that out, very cool!
flat-v8 is offline   Reply With Quote
Old 06-09-2012, 09:38 AM   #25
rotorwrench
rotorwrench's Avatar
Thats quite a fluid drive set up. It reminds me of the old airport tugs used to operate when I still worked at an airport. They had a fluid drive set up but still had a manual shift transmission with a clutch. Is that a chain drive to the rear driveshaft? I assume that is a shift mechanism on the side there with Neutral or Drive selection.
Nothing like 3600+ CCs to motivate!
Kerby
Old 06-11-2012, 12:03 AM   #26
Boscobill
Boscobill's Avatar
Was a chain at first, replaced it with a gear dive as it ate chains. The lever is to engage the "lock-up" style converter, a ball valve on the other side selects neutral.
Old 06-14-2013, 01:14 AM   #27
Boscobill
Boscobill's Avatar
Met up with an editor from a bike magazine at a local rally, here's a link to the article he wrote. Wasn't expecting that, just built the thing for fun!
http://iwblogger.com/2013/home-brew-flatty/
Old 06-14-2013, 07:33 AM   #28
JM 35 Sedan
JM 35 Sedan's Avatar
An awesome ride! Saw one similar to yours a few days ago at the Speedway Museum in Lincoln, Nebraska.
John
Old 05-06-2015, 12:48 PM   #29
Boscobill
Boscobill's Avatar
Latest photos, built a new tank and replaced the S&S carb with a 94.
File Type: jpg SCR-2015-best-custom-stretch-cruiser-770x492.jpg (137.3 KB, 116 views)
Old 05-06-2015, 01:12 PM   #30
john in illinois
john in illinois's Avatar
the solo seat and the bags really flow . The whole bike does not look like bits and pieces put together,but a solid design.
John
john in illinois is offline   Reply With Quote
Old 05-07-2015, 08:07 PM   #31
38 coupe
38 coupe's Avatar
Do you happen to know how much the bike weighs?
Very nice work.
Old 05-08-2015, 06:33 AM   #32
Boscobill
Boscobill's Avatar
995, give or take a pound or 2, really not a lot more than a full-dress hog or Goldwing.
The mpg is around 27-30 using a stock Holley 94 on a stock manifold with the riser cut off, carb is mounted to the top of the heat riser area, the heat risers blocked with copper pennies!
Old 05-08-2015, 08:04 AM   #33
Sid the Maineiac
Sid the Maineiac's Avatar
Just plain awesome !! I am duly and truly impressed with your ingenuity and workmanship !! Happy v8- ing !
Sid the Maineiac is offline   Reply With Quote
Old 05-09-2015, 11:55 PM   #34
Fredb_
Fredb_'s Avatar
Very Very cool bike!
Fredb_ is offline   Reply With Quote
Old 06-13-2016, 08:46 AM   #35
Boscobill
Boscobill's Avatar
https://www.facebook.com/danmmmm/vid...type=2&theater
Old 06-13-2016, 11:26 AM   #36
done4
done4's Avatar
Send a message via Yahoo to done4
Very cool, speaking of which how much heat does the flathead throw your way? Outstanding workmanship man!
Still smokin tires and cigars
done4 is offline   Reply With Quote
Old 06-13-2016, 12:28 PM   #37
Boscobill
Boscobill's Avatar
Not really any more, and likely much lower in degrees than that given off from an air cooled V twin. The temp rarely gets above 180. It is a daily rider as well.
