Old 07-13-2010, 09:48 AM   #1
Mark63
Mark63's Avatar
Default Wolf Whistle
I put a new wolf whistle on my intake manifold and it does not work. The wiper works well. The air just rushes through it with no whistle. What could be the problem?
Mark63 is offline   Reply With Quote
Old 07-13-2010, 09:52 AM   #2
TK in LA
TK in LA's Avatar
Default Re: Wolf Whistle
Not sure about the newer ones but the older ones have a spinning disk at the bottom of the trumpet. If yours has one check to be sure its free. Also check to be sure that the adapter to the manifold has a large enough hole. They like lots of vacuum!
Good luck!
Tom
TK in LA is offline   Reply With Quote
Old 07-13-2010, 10:01 AM   #3
Mike
Mike's Avatar
the new whistle out of the catologs are junk, the insides always fall out or just alot of air when you pull the actuating arm
Mike is offline   Reply With Quote
Old 07-13-2010, 11:38 AM   #4
Nick in Fayetteville
True or false? The wolf whistle allows cold air onto hot valves and therefore damages the valve.
Nick in Fayetteville is offline   Reply With Quote
Old 07-13-2010, 11:49 AM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
It would be sucking under hood air, which is usually quite hot. It would also be mixed with the much greater volume of carb air before hitting the valves. I say no danger.
I had a wolf whistle on my 55 Chevy in high school, and never had a problem.
Once in a while I'd have to spray some light oil on the whistle spinner to make it blow.
Also make sure the whistle spinner isn't installed backwards. The spinning disc faces AWAY from the open end of the trumpet.
Old 07-13-2010, 12:24 PM   #6
roadster
roadster's Avatar
i have a wolf whistle and thought it was not working
until i just pulled the wire a very slight bit and it worked fine.
roadster is offline   Reply With Quote
Old 07-13-2010, 12:36 PM   #7
Preacher
had numerous 'wolf' whistles. found MANY that were actually made wrong. they were the brass screw in motor type (the part that does the whistle is called the motor). many of mine had the screwdriver slot ON THE WRONG END. replacement motors are available from Speedway.
If it ain't broke, fix it 'til it is ...
http://tcmafc.org/
Preacher is offline   Reply With Quote
Old 07-13-2010, 12:52 PM   #8
Louis
Sound's like to many problem's with a wolf whistle.
Im going with a simple backfire sw. on my dash .
Louis is offline   Reply With Quote
Old 07-15-2010, 09:57 AM   #9
Preacher
yes, I have encountered other problems with them too. most notably is the cast ones always crack at the large threaded fitting creating a vacuum leak and making them inoperable. I make up new ones with a thicker base out of brass.
http://tcmafc.org/
