Old 07-07-2010, 04:01 PM   #1
MikeK
MikeK's Avatar
Default Re: Tie Rod rubbing on steering arm
[QUOTE=FlatheadTed;40302]Thanks for all the answers so far ,No reverse eyes ,
Ted, OK, some of us are looking at things upside down. Here's the pix you posted. Yesterday 2manycars said he saw a reversed eye spring, and that's what I see too. That's the problem. The bottom leaf should wrap over the top of the upper shackle bolt, not under then over it. That accounts for about an inch of drop. Look at another A spring in a catalog.
If you like where the vehicle sits and want to keep that spring you will need to make a custom drop drag link or elevated tie rod to give at least 1" clearance. The way it is, one good pot hole slam and the tie rod will pop the drag link off of the axle steering arm ball, leaving you with NO STEERING.
MikeK is offline   Reply With Quote
Old 07-08-2010, 09:55 PM   #2
CWPASADENA
CWPASADENA's Avatar
Question Re: Tie Rod rubbing on steering arm
[QUOTE=MikeK;40726]
I think if you look at the picture CAREFULLY, you will see the BOTTOM LEAF wraping over the TOP of the LOWER SHACKEL BOLT. The upper shackel bolt goes thru the spring perch. The picture is not very clear as to where the end of the Spring Main Leaf is.
Just my observation;
Chris.
CWPASADENA is offline   Reply With Quote
