Old 03-08-2012, 11:25 PM   #1
V4F
V4F's Avatar
Default question pleasedistributor
im having problems with my dist shaft building rust .the block casting where it narrows & goes thru the block . ive tried a gasket , a gasket with a thin coat of silicone , silicone along , grease . yes i oil it . it is crankcase moisture ?
thanks steve
V4f
V4F is offline   Reply With Quote
Old 03-09-2012, 12:06 AM   #2
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: question pleasedistributor
thanks steve
Steve,
I read somewhere that Ford ground a flat side on "B" distributors to "vent" that area because of condensation & rusting.
Horror story: Minerva's first Mallory seized the "never lube" bearings from condensation & rust in that area and ruined the distributor in just 2,200 miles! I ground 2 flats on the new one and also built my P.C.V. system. Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 03-09-2012, 12:39 AM   #3
Tom Endy
Tom Endy's Avatar
I suspect your head gasket is leaking one of the water jackets in the area of the distributor. Try re-torquing the head. You can also add a tube of aluma-seal to the radiator. It works good at sealing water leaks in the block without pluging it and the radiator up. The other alternative is to replace the head gasket.
It is always a good practice to remove the distributor at each oil change. Clean and re-set the pounts and put a coat of grease around the base of the distributor housing. You don't have to reset the timing as long as you do not loosen the cam screw.
the distributor can easily rust in place and become difficult to remove if you don't occasionally remove it.
Tom Endy
Old 03-09-2012, 08:49 AM   #4
V4F
V4F's Avatar
thank you both . i have had them seize up . strange happening . i have put in a pcv system for crankcase pressure on long high speed trips . cleaning the dist is a good idea , so will do ......... thank you .. steve
V4f
Old 03-09-2012, 09:31 AM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
I would coat it with antiseize. If you don't have that then use Mystik JT-6 High Temp grease.
Old 03-09-2012, 09:46 AM   #6
BILL WILLIAMSON
Steve & Tom,
Another thing I've always done, on stock distributors, remove the locating dowel pin on dist, you can locate it by eyeball and the lockdown screw will hold it in place well.Then if it ever seizes, along with penetrating oil, you can rotate it to get the danged thing out. (Tip # 947) Bill W.
Old 03-09-2012, 10:04 AM   #7
Tom Wesenberg
Bill,
The lcok screw should not be that tight though. It should just touch the distributor, then tighten the lock nut.
Old 03-09-2012, 10:42 AM   #8
BILL WILLIAMSON
Originally Posted by Tom Wesenberg View Post
Bill,
Tight within reason, after all, the dist does have an IRON body! To be "safe," I grind a sharp point on the end of the screw for a little "bite." I've run them for years this way with NO problems. Works for me! Bill W.
Old 03-09-2012, 11:31 AM   #9
V4F
V4F's Avatar
i do have never seize . never thought of using it . thank you .. steve
V4f
Old 03-09-2012, 11:35 AM   #10
VWJoe
VWJoe's Avatar
Use it . It gets everywhere anyway & you you can't wipe off for nuttin'
VWJoe is offline   Reply With Quote
Old 03-09-2012, 12:22 PM   #11
Brentwood Bob
I like tom's procedure to remove the distrib at oil change. The lower shaft is stuck to the oil pump driver on the huckster, guess it would benefit from removal also. Bob
Brentwood Bob is offline   Reply With Quote
Old 03-09-2012, 12:29 PM   #12
Bud
Bud's Avatar
FS Ignitions sells a stainless shaft.
Bud is offline   Reply With Quote
Old 03-09-2012, 01:20 PM   #13
Purdy Swoft
Purdy Swoft's Avatar
I think that it is a common problem. I use anti seize as has been mentioned. The problem is much worse with aluminum distributor housings, such as Mallory and others because of dissimilar metal reaction. When it has happened on our cars with Mallory distributors , I break out the large channel lock pliers, grasp the housing where it enters the head and gently rotate. I haven't ruined one yet.
Old 03-09-2012, 04:49 PM   #14
V4F
V4F's Avatar
i am taking all precautions . i will use all this info ... thanks all ............... steve
V4f
Old 03-09-2012, 09:40 PM   #15
Preacher
NEVER run the lock screw in tight to the distributor body. run it in to touch, then back of a titch.... 1/8 turn or so.
If it ain't broke, fix it 'til it is ...
http://tcmafc.org/
Preacher is offline   Reply With Quote
Old 03-09-2012, 09:47 PM   #16
SteveB31
SteveB31's Avatar
Anti Seize, Anti Seize , anti seize. Use it on that and almost every bolt. If you are going to own the car for a while, or care about the next owner of the car, anti seize makes things come apart easy years later. It should be used all the time.
SteveB31 is offline   Reply With Quote
Old 03-10-2012, 06:43 PM   #17
BILL WILLIAMSON
Everyone,
Then it ain't even a LOCKSCREW! You can't get it TOO tight with slot screwdriver! That's why they built it with a slot instead of a hex head bolt in order to"IDIOT PROOF" it against someone crushing the distributor body! Is there anything on a Model A that just requires just "finger tight?"
Including front wheel bearings which some will not accept that they need to be pre-loaded for proper operation and long life and good circulation of the grease.
I try to help with good mechanical practices that have worked for me, try to dispell old wives tales & old husband's tales. I don't know everything, but I ain't no ROOKIE either. I sometime use CORNY humor to maybe help folks remember something really helpful that I've posted.
I tell my buddies that I have a "147" I.Q. and I type and talk HOKEY POKEY OKIE, so as not to intimidate anyone! Some ask for good advice, then just argue, argue, argue against it!
If I didn't make any "POINTS" with this harrange, that's O.K. I didn't have any points stored up when I got up this A.M! (But the dog still loves me!) Bill W.
Old 03-10-2012, 08:56 PM   #18
Purdy Swoft
DING!!! DING!!! DING!!! DING!!! DING!!!!!!! Bill, you are making points here. I agree I tighten mine. You've just got to have the correct torque at the elbow and use common sense. You can imagine how quick a Mallory or any other modern style distributor would slip out of time if the set screw wasn't given some tension. Not trying to be a disagreeable old poot and make anybody mad. I know where you are coming from. Thanks for your input.
