03-09-2012, 10:42 AM
#11
Re: question pleasedistributor
Originally Posted by Tom Wesenberg
Bill,
The lcok screw should not be that tight though. It should just touch the distributor, then tighten the lock nut.
Tight within reason, after all, the dist does have an IRON body! To be "safe," I grind a sharp point on the end of the screw for a little "bite." I've run them for years this way with NO problems. Works for me! Bill W.
"THE ASSISTANT GURU OF STUFF"
