After reading this thread
http://www.fordbarn.com/forum/showth...393#post340393 After a few phone calls etc we made up two chevrolet conversions with a 1 inch taller profile. Hopefully this is another method of solving the belt clearance issue???? |
Bubba, you and I have traded e-mails. I am getting around the clearance problem using an idler pulley to bring the belt down under the distributor. What I have seen in trying to make the Chevy dizzy taller is that you run out of inside shaft length to go into the lower stabilizer fitting on what you previously called the Mercury type of timing cover. Are you making that shaft longer to make the taller housing?
#3 | |
I do like the support cover but there's no load on the ford distributor and the support really needed unless you plan on running a magneto. We might find the shaft will need a graft about half way up to use the support? |
I offered a solution to this problem a few months ago. However I like the idea of a longer distributor, I have one that's ahalf inch longer for an HEI unit I made 20 years ago.
Mr Bubba
I assume you could machine the chevy early mallory to fit 8ba and have it sit higher that the 8ba mallory?. If so ... is there enough shaft on the chevy to use it in the merc cover and still have it sit tall? |
I already have 2 of your dizzy's now I want a longer one for my next build. I am squeezing an 8BA in a 31 coupe and do not want to cut the firewall. After mocking up with new water pumps I will give you a call.
http://buildingahotrod.blogspot.com/ |
#7 | |
No the shaft is too short ,however we can do a shaft graft and make anything we need to fit the merc cover . Its only money i guess???? And it s your money not mine.. ![]()
Mr Bubba
Lookin at the chevy mallorys ... I have a ZC and a YC The YC looks better to me ... no big lump on the side. I will give you a call Thanks Greg |
Mallorys are not going to work even with an extra inch. I mocked it up and tried today.
![]() This is a Chevy Mr mallory that Bubba modified for me to use with a flathead. It is not fully engaged and definatlly will not work. ![]() In this picture the Mallory is not even in all the way ![]() as you can see its not going to work, maybe one without the tach drive might work ![]() Here is the regular bubba dizzy in my daily ride and as you can see add an inch and the belt can slide under there.
http://buildingahotrod.blogspot.com/ Last edited by bloodyjack; 01-12-2012 at 04:39 PM. |
bloodyjack
It looks like the fan will clear the dist …. yes? It also looks like an idler on the back side of the belt would get it under easy. Im wanting to run a gen mounted fan w 8ba dist in my 35 coupe. 8ba motor (motors done … don’t want to change cams) Early heads Iv got the 8ba mallory and a gen and fan on now and it (the fan) is very close to the dist but I have room to shim fan out a bit. |
I previously posted this in another thread. Still smoothing up the idler pulley assembly opposite the distributor and going to use a larger diameter pulley on that side. I mount the alternator in the lowest position and will adjust the bigger pulley to take in the slack. This engine is a 59A with a cam adapter gear and Roberts gear cover.
Sweet
Wanted Ford oiler oil cans Thanks |
#13 | |
#14 |
Ford never made a DIZZY, they did however make distributors!
#15 | |
Lonnie |
#16 |
Thanks Binx some people don't have informative content in there posts.
http://buildingahotrod.blogspot.com/ Last edited by bloodyjack; 01-17-2012 at 04:14 PM. |
#17 |
Just recieved my package from Bubba and it fits, just. ![]() Now I just need to find an old style bottom pulley ![]()
#18 |
some of the problem with your set up bloody jack is that you have the early generator and water pumps causing the belt to ride closer to the block.
#19 |
That's true, but we must solve ALL problems,or, there's many ways to skin a cat.
| Thread Tools | |
| Display Modes | |
