Old 12-29-2011, 04:39 PM   #1
Bassman/NZ
Bassman/NZ's Avatar
Default A "just because" picture.
This is the C59A in my AV8. It is dead stock with the exception of duals and Smithys. It runs 65lbs at startup and drops to about 40lbs when hot. It's backed up with a 36 trans and 47 rear.
Down the track a little I plan to run twin carbs, a set of headers and mill the heads to raise compression a bit. However, it runs pretty good in a light car, so no priority on the mods.
Bassman/NZ is offline   Reply With Quote
Old 12-29-2011, 06:12 PM   #2
40cpe
40cpe's Avatar
Default Re: A "just because" picture.
Thank you just because for posting that nice picture. We need to see the rest of the car!
Old 12-29-2011, 08:47 PM   #3
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Hey Bassman, I just built a C59A for a guy in Canada. It's the first one i"ve see. Do you know what year that engine is? Is the bore 3-3/16? Does it have 2 core plugs in the each pan rail? Does it pass the pencil test on the front of the block? This was an interisting engine for me. It seemed to be half an early 39-41 block and half 46-48. Thanks Walt
Old 12-29-2011, 08:50 PM   #4
37slantback
Sometimes I wish I had kept the stock heads. That is really nice!
37slantback is offline   Reply With Quote
Old 12-29-2011, 09:21 PM   #5
Bassman/NZ
Bassman/NZ's Avatar
Walt, it's from a 47 Ford. Here in NZ they used Canadian engines. It is 3 3/16" but I didn't take any notice of the core plugs. It has C59A cast on the block just in front of the left hand head. I've changed the distributor from rabbits ears to crab type. It runs real strong. It also has an 11" clutch which it seems was std here in NZ for 47-48 Fords.
Old 12-29-2011, 09:22 PM   #6
Bassman/NZ
Bassman/NZ's Avatar
Well if you insist....
Old 12-29-2011, 09:42 PM   #7
G.M.
You can tell if it has the core plugs above the pan rail by looking at the side of the block above the pan rail. The early blocks with core plugs have two humps on the side of the block. The later blocks are smooth. G.M.
www.fordcollector.com
Old 12-29-2011, 10:15 PM   #8
52merc
52merc's Avatar
all canadian c59 a engines had the plugs different than usa engines theres also a c69 blocks that had real thick walls you can bore them right out with no worries, they where all 3 3/16thstrev
ps hows things marty sorry not getting back to you but the puter had some problems lost a few address,es
52merc is offline   Reply With Quote
Old 12-29-2011, 10:50 PM   #9
Brian
Brian's Avatar
And the C69A blocks do not have the plugs in the pan rails unlike the C59A blocks. Brian
Old 12-29-2011, 11:03 PM   #10
David J
David J's Avatar
Bet it scoots pretty good . What's it weigh ? On having 40 # of oil pressure hot - The oil gods like you . On my last summer's wheels 33 -w- 33 motor the oil pressure NEVER reached 10 # hot & it would be 1-2 # at slow idle . . It will peg the old 50 # gauge cold . Runs fine & it got around a bunch last summer . CAM BEARINGS were a HUGE improvement in 1935 .
David J is offline   Reply With Quote
Old 12-30-2011, 12:57 AM   #11
kiwi88
Is that an old photo? I'd be p....d if you took it today given the rest of us are suffering torential downpours and not driving our roadsters.........
kiwi88 is offline   Reply With Quote
Old 12-30-2011, 12:43 PM   #12
Walt Dupont--Me.
Bassman, that is the same block I built for a guy in Canada, also the 3 big water holes in the block head gasket surface, the bottom hole had 59 right in the center. I bored this to 3-5/16 and used a Merc 4in. crank and Max 1 cam, 38 heads witch are smaller and the guy is useing a 4bbl carb I think. Walt
Old 12-30-2011, 02:47 PM   #13
Bassman/NZ
Bassman/NZ's Avatar
Haha I wish. That was taken Christmas Eve, right after taking my wife for the first run in it. She was stoked!
It's currently pissing down here.
Old 12-30-2011, 02:58 PM   #14
flatheadernie
Awesome looking ride, thanks for posting, ernie (46 coupe) n tx
flatheadernie is offline   Reply With Quote
Old 12-30-2011, 05:26 PM   #15
kiwi88
Very cool ride. Look forward to seeing it at the Beach Hop (rain or shine).
