Old 10-07-2011, 06:27 PM   #1
Don in so Cal
Default Hinge pin replacement
Hi, Barners
Is it better to drill for oversized hinge pins one at time with the door still mounted to the car or is it better to take the hinge apart and do each half
separately?
Many thanks,
Don
Don in so Cal is offline   Reply With Quote
Old 10-10-2011, 05:31 PM   #2
Ken/SC
Ken/SC's Avatar
Default Re: Hinge pin replacement
I would say it is better to drill with the hinge on the car. It is what we call Line Drilling in a machine shop. Also I would check the bolts holding the hinge to the car before putting in oversized pins. I had a door dragging on my tudor, started to put the new pins in and realized that the bolts were loose.
Ken/SC is offline   Reply With Quote
Old 10-11-2011, 12:33 AM   #3
Dan Partain
Dan Partain's Avatar
I had to take the upper hinges (and maybe the middle hinges) off of my 29CC to drill them. The drill would hit the hinge pillar and made it so I couldn't get a straight shot into the hinge with the drill bit. If you have a narrow drill motor you may be able to do it.
Dan Partain is offline   Reply With Quote
