Old 09-28-2011, 10:15 AM   #1
Ken Ehrenhofer
Default Rebuild kit for hydraulic brakes
I am trying to find wheel and master cylinder rebuild kits for a converted Model A. I have tried Clings and others with no luck,
Can anyone give me some info,
Thanks in advance,
Ken
Ken Ehrenhofer is offline   Reply With Quote
Old 09-28-2011, 10:43 AM   #2
Russ/40
Russ/40's Avatar
Default Re: Rebuild kit for hydraulic brakes
You need to determine which brakes you have before you can say what you need.
Old 09-28-2011, 10:49 AM   #3
Ken Ehrenhofer
OK I am assuming you want to know what year Ford Brakes we have?
How do I identify what it is??
I am new at this. I am a Model A Man and we have steel rods!!! LOL!
Thanks,
Ken
Old 09-28-2011, 11:14 AM   #4
Butch11443
Butch11443's Avatar
You should have either 39 to 42 brakes or 46 to 48 brakes. Determine which you have and you can order the parts at any good parts house.
Butch
Butch11443 is offline   Reply With Quote
Old 09-28-2011, 11:20 AM   #5
Charlie Stephens
There is about a 95% chance that your brakes are 1939-48. The prewar brakes adjust at the bottom and the sides. The postwar adjust only at the sides. The prewar shoes have a round hole at the bottom of the brake shoe and the postwar shoes have a slot at the bottom for the shoe to move up and down. Post a picture showing the adjustment (or lack of it) at the bottom and someone will id your brakes.
Charlie Stephens
Old 09-28-2011, 11:52 AM   #6
Richard (EV8G)
Richard (EV8G)'s Avatar
IF they are Ford/Merc/Lockheed brakes, the rear wheel cylinders are the same 39-48. The fronts could be 1-1/4" forward piston diameter (39-41) or 1-3/8" forward piston diameter (42-48) but the earlier brakes could now have the larger cylinders, since for a long time, the new cylinders have only been available in the 1-3/8" size.
If any of the cylinder bores are badly pitted and would therefore require alot of honing to clean up, you should consider buying new wheel cylinders. Also, the rebuild kits do not come with new pistons and often the old pistons are nasty.
Sometimes they are so corroded, they cannot even be removed. If the cylinders are honed too much, the seals will not seal and you will end up with
brake fluid on the new linings... and will have wasted alot of time rebuilding the old cylinders and money for the kits and new lining.
Same goes for the master cylinder.
I would avoid the new South American cylinders.
Early V8 Garage
Pasadena Roadster Club
Richard (EV8G) is offline   Reply With Quote
Old 09-28-2011, 04:14 PM   #7
Bassman/NZ
Bassman/NZ's Avatar
Macs Auto or C&G Early Ford will have the stuff you need, but as others have said, you need to determine the exact years of your brakes.
Bassman/NZ is offline   Reply With Quote
Old 09-28-2011, 06:41 PM   #8
1931 flamingo
1931 flamingo's Avatar
JobLot in NY?
Paul in CT
Old 09-28-2011, 07:50 PM   #9
Ken Ehrenhofer
OK so now I know how to identify them and where to buy the parts I need!
Wow this Ford Barn is a super place...Thanks to all. I will identify them and if I have more questions I might be back,
Thanks,
Ken
