I got caught in the rain in the 47 pickup yesterday and my trico has long since worked so I thought a rebuild is in order. I have it all apart and I am wondering what kind of grease is used in these? The original grease is redish in color, what can I buy that that will work in the rebuild? No parts houses mention it.
Respecting and Resurrecting Ford Model A's. |
Vasoline works for me.
Vasoline huh, I will give it a try. How much do I use??
Just coat things lightly.
clean gook from between leathers with a pick
use no strong solvents that might dry leather good luck |
~~Walts37~~ |
I just took it apart after it had sit in a pasture for 35 years cleaned everything up & applied Vaseline to all moving parts left a little extra inside I think I had to make a new gasket & put it back together works great.
~~Wallts37~~ |
Used silicone grease in mine in 1985, then car sat for 25 years indoors. Thought I would have to go through it again, but it still works fine. I used just enough to coat the paddle and lube the inside of the housing.
I just filled mine with 3 in 1 oil and let it sit for a day. Drained out the oil and put in a new line, works great. That is after for 38 years.
Bill |
Not much to rebuilding one, but the gaskets are a problem to make. Anyone know of a source for rebuild kits, especially the gaskets.
Mac's has the gaskets and full rebuild parts. I just used some vasoline and put it back together with a rebuild kit. It works! I can actually make it move back and forth by sucking in on the inlet tube. Must have done something right.
| Thread Tools | |
| Display Modes | |
