Old 05-01-2026, 11:34 PM   #1
Ford Freak
Default Master cylinder line fitting?
Hello - I am changing my brake system back to original 4 wheel drum on my '56. I have a new single bowl master cylinder. What fitting do you all use on the single brake line coming out from the master? Is it NPT threaded? Help! Thanks in advance. - F F
1952 Ford F1
!956 Fairlane Club Sedan
1965 Falcon Sprint
2007 Mustang GT
Ford Freak is offline   Reply With Quote
Old 05-02-2026, 12:14 PM   #2
Als48
Default Re: Master cylinder line fitting?
I'm fairly sure those connections are inverted flare, so threads are likely 3/8"-24 or 7/16"-20 SAE fine threads. Straight machine thread, not pipe thds.
Als48 is offline   Reply With Quote
Old 05-02-2026, 01:11 PM   #3
Gene F
Gene F's Avatar
Back, back form what? Why?
Old 05-02-2026, 01:28 PM   #4
Ford Freak
I am changing it back to stock from a half a$$ed front disc brake conversion set up (on the car when purchased) that never worked to my satisfaction. For the little bit that I drive now, the drum-drum brakes will be fine. Anyways, I found the fitting I was looking for this morning. Thank you! F F
1952 Ford F1
1965 Falcon Sprint
2007 Mustang GT
Old 05-02-2026, 07:16 PM   #5
paul2748
paul2748's Avatar
CASCO has the fitting and the special bolt that holds it. Plus the two washers that are used with it. Part #'s 2076A,2276, 2154. I don't know if the sedans used the heat shield, but they have that too.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 05-02-2026, 10:54 PM   #6
Ford Freak
Thanks Paul! Just what I needed. Ordered the 4 pieces tonight. Once again, the Barn has helped me out. Love this site!! - F F
1952 Ford F1
1965 Falcon Sprint
2007 Mustang GT
Old 05-03-2026, 09:27 AM   #7
cos
The copper crush washers are a special size, they have been in business for a long time, should have right ones.
cos is offline   Reply With Quote
Old 05-03-2026, 11:00 AM   #8
Ford Freak
They say that they do. Thanks!
1952 Ford F1
1965 Falcon Sprint
2007 Mustang GT
