Old 04-26-2026, 01:44 PM   #1
Steve Fehniger
Steve Fehniger's Avatar
Default Wheel bearing grease recommendation?
Ford Barn team,
I have a basic question regarding recommendation for wheel bearing grease as I need to reassemble rear drums on '33 pickup and would like to use the correct grease. Recommendations requested.
Thanks in advance,
Steve
Keep V-8ing
Last edited by Steve Fehniger; 04-26-2026 at 02:22 PM. Reason: pulled out reference to chassis grease
Steve Fehniger is offline   Reply With Quote
Old 04-26-2026, 03:15 PM   #2
aussie merc
aussie merc's Avatar
Default Re: Wheel bearing grease recommendation?
any good quality htb grease thats readily available in your area .Whats around now is far better than the 30s
aussie merc is offline   Reply With Quote
Old 04-26-2026, 03:26 PM   #3
Steve Fehniger
Thank you Aussie Merc. I will assume htb = high temperature bearing. I appreciate the input.
Old 04-26-2026, 06:00 PM   #4
alchemy
alchemy's Avatar
Multiple threads going on this topic (link to one posted below). The long favorite from Sta-bil is made no longer. Some folks have investigated and found an alternative, but I haven’t seen anyone say just any good quality grease is fine, until now.
https://www.fordbarn.com/forum/showt...6869&showall=1
alchemy is offline   Reply With Quote
Old 04-26-2026, 10:38 PM   #5
Oldcarbearings
Location: North Warrandyte, Melbourne,Victoria, Australia
TIMKEN wheel bearing grease by the company who supplies(d) FORD as OEM tapered roller bearings WHO better to make a grease than the company that makes bearings?!......
Oldcarbearings is offline   Reply With Quote
Old 04-27-2026, 12:45 PM   #6
alchemy
alchemy's Avatar
He said rear, so not tapered. Same recommendation?
Old 04-27-2026, 06:38 PM   #7
Steve Fehniger
Thank you for the input, Alchemy I appreciate the thread which I read through. I'm starting from clean with a new seal and yes, rear bearings so no taper. I am considering TIMKEN GR224TUB Grease which is "premium hi-temp red" per the container on Amazon. I would welcome any other thoughts from the Barn.
Steve
Old 04-27-2026, 07:00 PM   #8
Oldcarbearings
Yes same grease doesn't matter WHAT type of bearing (s) you're lubricating with the exception of fully rubber sealed bearings they DON'T need grease as they're packed from the factory with grease......
Old 04-28-2026, 05:56 PM   #9
Steve Fehniger
All, thank you for the input and insight.
Keep V-8ing
Steve
Old 05-01-2026, 10:22 AM   #10
1948F-1Pickup
1948F-1Pickup's Avatar
The Timken grease is the preferred stuff currently. And affordable.
The only stuff that beats that is made by Klüber. And is not inexpensive by any measure.
1948F-1Pickup is offline   Reply With Quote
Old 05-09-2026, 12:12 PM   #11
Steve Fehniger
Thanks 1948 pickup. I appreciate the confirmation.
