I see ads for the tank extension but I can’t figure out how it makes fueling easier.
It provides enough of a rise to disable the nozzle from shutting off.
Do you only install it when fueling or does the gas cap fit on it?
Only install it when refueling, there is no provision to install the cap on the extension.
The Master Cylinder Enjoying life at the beach in SoCal... |
It's useful here in the peoples republic of CA to hold the sealing ring of the vapor recovery nozzles back so you can get 2-3" more gas in the tank.
People in the free world with normal nozzles don't need them. I saw a couple months ago the maker was going to retire from making more. |
#7 | |
Photochemical smog is a type of air pollution characterized by a brownish haze that forms in urban areas, primarily resulting from the reaction of sunlight with pollutants like nitrogen oxides and volatile organic compounds (VOCs). It is often referred to as "Los Angeles-type" or summer smog, commonly appearing in sunny, warm, dry climates with high traffic density. |
I would think one could make a temporary extension from a short piece of PVC pipe.
_______________________ The other Bruce in Minnesota 1931 Model A Closed Cab (Budd) Pickup "Aurora" Model A Ford Club of America Lady Slipper A's "You can't go back and change the beginning, but you can start where you are and change the ending." - C.S. Lewis |
I use a pvc socket to male npt adapter. I'm away from home, so I don't know the size.
#10 | ||
Ever wonder why modern cars still use metal filler necks? |
When you pump gas and the metal nozzle touches the tank it makes a ground path for static electricity, with a PVC adapter no path for static electricity, keep your free hand in contact with the gas tank opening and the pump nozzle . i was taught to keep the pump nozzle in contact with the tank opening refueling light planes at the local airport as a teenager . As an inquisitive kid I asked about the rubber hose and was told fuel hoses conduct electricity by wire embedded in the fuel hoses .
I hold up the California nanny collar with one hand, bridge the resulting spout across the tank making contact, then use the other hand to operate the handle. Much like NK notes above, but being sure to maintain a static ground path. Pretty easy to do once you’ve done it a couple of times.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan (under reconstruction) 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
#13 | |
#14 |
I like the extension. Works great even in Cali. No gas spills and ez to use.
#15 |
Another benefit of the extension, you can't dent the top of the fuel tape ring which would case the cap not to seal...........thus a fuel leak when the tank is full.
AL in NY |
#16 | |
BTW: for the last 15+ years Ford had used plastic fill necks - and tanks. |
#17 | |
| Thread Tools | |
| Display Modes | |
