#21 |
On my Avatar 2N tractor with 8BA I started with a factory 6V starter used at 12V. It did seem to hit a little hard so I bought a '63 390 Thunderbird starter that was 12V to begin with and used the flathead armature and drive in the Thunderbird case. It worked like a charm.
Then I put the engine in another tractor (8N) and bought a Powermaster mini-starter so I did not have to cut the transmission case/bellhousing on the tractor. They are kind of nice but definitely not period correct looking. |
#22 | |
#23 |
Didn't want to hijack the thread but here is a picture of the other side.
#24 | |
#25 |
We're going thru an 8N right now. Hmm, I do have a spare 8BA.......
#26 |
#27 |
That's a nice write-up on that V8 conversion. One of those potential projects which I try to suppress the urge for. Yours really looks great.
#28 |
I hope those cradles under the 8BA are pretty stout. The N, NAA, and 600/800 series use the engine block with a heavy pressed steel front mount for the front axle attachment. I've had to weld those front mounts up due to cracks before. That cradle that ties the trans to the front end will have to be pretty heavy duty to take the bump and grind of field operations. If a person just plows a nice flat field or drives it for show then it may be OK.
#29 | |
#30 |
I'll go search it, but are those things that one can find currently? ^^^
| Thread Tools | |
| Display Modes | |
