Old 04-02-2026, 05:03 PM   #1
Tudie 36
Tudie 36's Avatar
Default Head numbers help
IMG_1934.jpg1936. Has it been factory redone?
Tudie 36 is offline   Reply With Quote
Old 04-02-2026, 05:33 PM   #2
mcgarrett
Default Re: Head numbers help
Not sure if they are genuine Ford, but appear to be service replacement heads, judging from the late casting dates. The "40" prefix indicates heads for 1933 & 1934 V8.
Old 04-02-2026, 05:35 PM   #3
Tudie 36
Tudie 36's Avatar
That’s what I thought also
Old 04-02-2026, 06:47 PM   #4
Kube
Super Moderator
Kube's Avatar
These are most likely service parts from Ford.
Last edited by Kube; 04-05-2026 at 10:52 AM. Reason: corrected my earlier (incorrect) opinion
Old 04-03-2026, 08:47 AM   #5
Terry,OH
Terry,OH's Avatar
The 36 could have flat top or domed pistons. The 40- indicates the heads are for flat top. The part number suffix "B" indicates the heads are cast iron. The 40- heads were used into 35. There are many different heads used by Ford. Suggest you look in the V8 Club restoration book for 35-36 and it's updates on the club form.
Old 04-03-2026, 12:22 PM   #6
Kube
Super Moderator
Kube's Avatar
Yes, many design changes were made in '35 / '36. However, only aluminum heads were installed upon the assembly line.
Last edited by Kube; 04-05-2026 at 10:53 AM. Reason: corrected an earlier "duh" moment of mine
Old 04-04-2026, 01:24 PM   #7
Model51
Model51's Avatar
On the assumption your "36" is a car, Kube is correct in that all production car engines in 1936 came with aluminum heads. The 40-6049/50-B heads were available for flat-topped pistons as service replacements for the production aluminum versions.
The cast iron 40-6049/50-B were the standard production heads for trucks from 1934 through 1936, so they are correct for those vehicles.
The embossed date tags indicate the heads are made as service replacements. Mid-1930's production heads made by Ford do not have date tags.
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 04-04-2026, 02:51 PM   #8
Kube
Super Moderator
Kube's Avatar
The embossed date tags indicate the heads are made as service replacements. Mid-1930's production heads made by Ford do not have date tags.[/QUOTE]
Old 04-04-2026, 08:47 PM   #9
highbeams
highbeams's Avatar
Thank you all for this information. My '33 has the replacement heads then.
highbeams is offline   Reply With Quote
Old 04-05-2026, 07:48 AM   #10
Model51
Model51's Avatar
Kube - There are two pictures of the 40-6049-B head (looks like a duplicate photo) with a 10-1-48 date, and one picture of the 40-6050-B head with a 5-20-48 date.
Old 04-05-2026, 08:19 AM   #11
Kube
Super Moderator
Kube's Avatar
I'm going blind... no other excuse. Well, maybe one more... I'm goofy in the head.
Thanks
Old 04-05-2026, 09:50 AM   #12
Model51
Model51's Avatar
Easy to do - I do it all the time.
Old 04-16-2026, 06:17 PM   #13
Tudie 36
Tudie 36's Avatar
thanks
