Old 03-31-2026, 10:41 AM   #1
Feathercraft56
Feathercraft56's Avatar
Default 59A motor in 1934 Fordor sedan
Hello all. Is there any modification needed to install a 59A Flathead motor in 1934 stock fordor sedan? Any help would be greatly appreciated.
Kind regards
David Ahlf
Feathercraft56 is offline   Reply With Quote
Old 03-31-2026, 11:41 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 59A motor in 1934 Fordor sedan
You will need these spacer adapters. Ebay # 375966016881.In the description they also have the radiator hoses that you will need also.
Old 03-31-2026, 01:30 PM   #3
glennpm
glennpm's Avatar
You also need a generator mounted fan and single sheave crankshaft pulley.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 03-31-2026, 01:35 PM   #4
cas3
usually you have to cut the front pulley off the crank pulley. Then, the crank is a little longer so it will hit the loop for the hand crank. Some cut this off, or you can buy a new one for a model A and cut that. You need to aim for the height of the crank nut to be in the same position, like you're gonna use the hand crank, or if too high you run out of clearance for the breather tube at the firewall. Even at the correct height its hard to get the breather cap off and on, so I made a longer tube to get the cap above the firewall.
Also, the height needs to be just right to be able to change fan belts when needed.
Old 03-31-2026, 02:42 PM   #5
cas3
I wanna see a pic of the 56 feathercraft too.
Old 03-31-2026, 04:13 PM   #6
The Art Doctor
The Art Doctor's Avatar
I have two Feathercraft also, a 51 DR and a 59 Deluxe Clipper.
The Art Doctor is offline   Reply With Quote
Old 03-31-2026, 04:27 PM   #7
cas3
Nice! Neighbors had one of the streamlined jobbers when I was a kid. I always thought it was the coolest boat around.
Old 04-02-2026, 11:55 AM   #8
Feathercraft56
I Had a 1957 Vagabond II Runabout for many years and loved that boat. Coolest aluminum boats ever made and I think I put a million miles on it. I got stopped every time I took it out by people wanting to know all about it and if it was for sale.
Old 04-04-2026, 10:15 AM   #9
IMoveMetal
IMoveMetal's Avatar
I just finished this swap on my ’34 Sedan. I made a few posts a while back and got a lot of help from the forum on this.
I kept the original front crossmember hoop, which ended up being the biggest constraint. I wanted to retain it and still be able to turn the crank through the hoop, so clearances at the front became critical.
As mentioned prior, I had to machine down the crank pulley. There’s just no extra room there with a later flathead. Once I did that, everything finally cleared properly without modifying the hoop.
Motor mounts were not even close to usable as-is. I ended up building them using the stock setup as a base, then machining a 1" solid steel spacer and adding additional urethane bushings to get the engine height where it needed to be. That height is what allowed the pulley and hoop to coexist and still maintain alignment.
On the rest of it:
* I had no issues with the breather fitting, despite what gets mentioned a lot
* Transmission bolted right up with no issues at all
* The real work is entirely at the front of the engine
* Those eBay engine mounts did not work for me, they are offset and did not work with my water pumps
Here are a couple pics of how it ended up:
IMoveMetal is offline   Reply With Quote
Old 04-04-2026, 10:25 AM   #10
cas3
Yeah, I made my own front brackets too, to get the height exactly where it needs to be.
Yours looks good, tight though! can you still slip a fan belt thru the crank and guide?
Old 04-04-2026, 10:41 AM   #11
IMoveMetal
IMoveMetal's Avatar
The belt just slips by but is very tight. I may swap to a model A saddle at some point without the hoop if I can find one.
Old 04-04-2026, 10:53 AM   #12
glennpm
glennpm's Avatar
Please post a couple of closeup photos of your motor mounts to crossmember. Can't see this detail in the pics you posted.
Old 04-04-2026, 11:57 AM   #13
tubman
tubman's Avatar
I believe the "eBay spacers" with the offset are meant to put an engine with '49-'51 Merc pumps into an earlier chassis. Hence the offset.
Old 04-04-2026, 12:05 PM   #14
IMoveMetal
IMoveMetal's Avatar
Here are some close-ups from the mock-up. I’ve since changed out the hardware, but this is the stack I ended up with.
I made a 1" × 3" round steel spacer and beveled the bottom so it nests into the crossmember. On top of that I used the standard motor mount, then added fender washers and a urethane bushing to dial in the final stack height.
Old 04-04-2026, 01:08 PM   #15
glennpm
glennpm's Avatar
Thanks!
Old 04-04-2026, 05:17 PM   #16
Newc
Newc's Avatar
Had to install stock steering box BEFORE engine. Special Rt exh header from Reds $$. Merc mounts still toooo low. Got it to fit tho. Newc
