The tips of the push rod might be hardened, especially the end that rides on the cam.
Get the correct rod , if possible. Here's an idea: Make an adjustable push rod. |
Super Moderator
100% correct in the hardened tip advice. The early engines used the rod that was 1" shorter than the later rods. They are readily available from Carpenter, etc.
| Thread Tools | |
| Display Modes | |
