I am working through the banjo on my '39. Thought I should upgrade the torque tube while I have it out. The rest of the car is all original (what I mean is if replacement parts were used they replicated the original parts).
But, when I looked at the bearing race on the torque tube (front), it is not split. Rather it is a solid race, definitely not original design. Has anyone seen this style replacement race? And if so, how to remove in order to get to the seal? |
#2 | |
Super Moderator
#3 | |
If so, so race car clamshells are one piece and designed for a straight tube torque tube. It would be helpful if you can post of picture of the part you are referring to. We're happy to help. |
Which part in this pictorial are you dealing with?
Open and scroll down. Is it 4655 ? https://www.jalopyjournal.com/forum/...l-seal.941155/ |
#5 | |
#6 | |
Location: North Warrandyte, Melbourne,Victoria, Australia
ONLY the sleeve which houses 4645 is split it's made originally by HYATT also : BERLISS/BOWER/RBC/SKF also made it extremely expensive here in Australia to find/locate/source the OEM ORIGINAL FORD/HYATT type !!!!!, the FORD spare parts vendors in the USA have them far&way cheaper than what i have to pay for them form USA!!!!!
, i can provide the aftermarket (bearing companies) part number for the sleeve?.....
Yes, I am referring to 4655; most replacement guides indicate that this is a split shell that is twisted out of its detent with the appropriate tool.
But the race (shell) I have is solid. Ken/Alabama; how did you remove the solid race and seal from your vehicle? I assume since it was a 39 it had a bearing in the middle of the torque tube. |
HYATT part number: 5150, BOWER F68-1236.
Bower j663657/hyatt 00536,
This issue has come up and been discussed on here before. There is a thicker walled bearing outer race in some torque tubes from the factory. Try doing a search of earlier threads about this....
here is an earlier thread, made by you in 2017 about this bearing. https://www.fordbarn.com/forum/showt...e+tube+bearing
#13 |
Yes some of the original Ford races were solid and not split.
#14 |
Is it possible that the one piece bearing race was pressed in first, followed by the seal?
That would make it easier to remove the seal without having to remove the race. |
#15 |
Brian,
Mea Culpa; Alzheimer's has set in. By the way any tips on using the search feature? When I, for example, type in Torque Tube seal removal, I get back Torque tube answers, seal answers, making research inefficient. Other search sites allow coupling the search parameters such that your get a targeted search. Am I missing something? |
#16 |
Tubby,
Try putting your search terms in quotes. Ken
https://www.nirgv8.org |
#17 |
This is what I did along with good suggestions from 19Fordy.
https://www.fordbarn.com/forum/showt...ue%2Atube+seal
Archives of historical but relevant older articles: ------------- Hover mouse over the links below and click! ~~~~~~~~~~~~~~~~~--------------- Rumble Seat’s Notes Techno Source for the 1932 thru 1953 Flathead Ford |
#18 |
#19 | |
#20 |
Glenn, Thanks for the arrow.
| Thread Tools | |
| Display Modes | |
