Old 03-12-2026, 07:39 PM   #32
WarbirdPhotog
WarbirdPhotog's Avatar
Default Re: 3D Printed Ford Battery Case Help
Originally Posted by ford38v8 View Post
Warbirdphotog, your mentioning a possible redo of the cell tops due to a suggestion that they were too tall. I'll refer you to my post #20 from last year on how I made my Ford LF: I used 1/16" ABS for the battery top, with 3/16" ABS on top of that for the cells. This makes the total thickness exactly ¼", which provided the needed additional space for the terminals. If you decide to do a remake, consider also using actual tar on the cell surrounds for authenticity? One more tip, the gold paint is easily applied with a rubber hobby roller.
Hello, thanks for the measurements. I actually mimicked the tar texture, to a degree, using some textured 'grain' paint. Using actual tar is a bit beyond what I would want to do, especially when you can mimic it.
As for the gold, I actually tried it with a rubber hobby roller, funny enough, and it looked terrible! So I switched to the spray paint after that.
1940 Ford DeLuxe Fordor Sedan
1944 GPW Jeep
WarbirdPhotog is offline   Reply With Quote
