Old 02-21-2026, 07:55 PM   #1
tubman
tubman's Avatar
Default Re: Transmission locked up - please help
You probably have it in two gears at once. I would fiddle with the levers for a while and it might just come out of one. There is an interlock on the transmission side cover that is supposed to prevent things like this. It may have been overcome, allowing the gears to jam and is now preventing them from going back. You may have to remove the side cover and manually manipulate the gears. Be careful when you do this as the shift forks want to fall out of the cover if you hold it wrong.
Uhh, I suppose this not not a good time to make an offer on that great looking truck, is it?
Old 02-21-2026, 08:03 PM   #2
jonahboo
jonahboo's Avatar
Originally Posted by tubman View Post
You probably have it in two gears at once. I would fiddle with the levers for a while and it might just come out of one. There is an interlock n the transmission side cover that is supposed to prevent things like this. It may have been overcome, allowing the gears to jam and is now preventing them from going back. You may have to remove the side cover and manually manipulate the gears. Be careful when you do this as the shift forks want to fall out of the cover if you hold it wrong.
thanks
first time under the truck....not sure what position the levers want to be at
my understanding is there are 3 positions for each
can anyone tell from photo which way i might try to coax one?
jonahboo is offline   Reply With Quote
