Old 02-13-2026, 08:18 PM   #1
Vanspeed
Vanspeed's Avatar
Default 35/35 truck firewall pad bolts
I have had a few 35 trucks but noting ever nice and nothing had the firewall pad still in it. I just replaced (temporary in place) a botched up firewall on a ‘36 cab and the donor firewall had 13 of these bolts. They look like they held the original pad on. I count that I need 16. I have 13. Is there a source for these?
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 02-13-2026, 08:27 PM   #2
al's28/33
al's28/33's Avatar
Default Re: 35/35 truck firewall pad bolts
check epay every once in a while someone will have a couple. I'm sure the Hershey swap meet will have some. maybe even Bert's in Colorado might have a source to help you but to my knowledge they are not reproduced. 33-34 pickups used them too
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 02-13-2026, 08:41 PM   #3
paul2748
paul2748's Avatar
Something similar are sold by the 55-57 TBird suppliers and are for the same reason. Not sure the size and length are the same, you should be able to ask the supplier for the dimensions. For CASCO, they are Firewall pad to firewall fastener. , part # 357036S ZC
Also check with the Early Ford parts suppliers. They seem to be a part that Ford used for many years.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 02-13-2026, 09:00 PM   #4
hotcoupe
hotcoupe's Avatar
If all else fails, that would be an easy project for someone with a lathe. I used to be in the same frame of mind, (where can I buy this or that). I bought a tool room lathe twenty years ago and it has solved a lot of problems for me.
Hope this helps,
Tom
hotcoupe is offline   Reply With Quote
Old 02-13-2026, 09:29 PM   #5
36and63
36and63's Avatar
My 36 had the push-pin style holding what I believe were the remnants of the original pad. The aftermarket ones available are poor quality but can be made to work. I don't recall seeing any like those you have in your pics.
Pat
36and63 is offline   Reply With Quote
Old 02-13-2026, 10:00 PM   #6
Don Rogers
Don Rogers's Avatar
Early and mid 1935 trucks used the special bolt that you have part # B-35362. 1936 firewalls used a split metal fastener. Neither will be easy to find. Try 3rd Generation Automotive Michael Driskell.
Don Rogers is offline   Reply With Quote
Old 02-13-2026, 11:40 PM   #7
petehoovie
petehoovie's Avatar
Old 02-14-2026, 01:53 AM   #8
deuce lover
deuce lover's Avatar
Third Gen has them
Old 02-14-2026, 12:52 PM   #9
37 truck
Quite ride solutions makes reproduction pads and has the split-type pins
37 truck is offline   Reply With Quote
Old 02-15-2026, 10:54 AM   #10
35fordtn
35fordtn's Avatar
We used to make these and stopped about a year ago. I may make one more run of them soon. You can take a 5/16 partial threaded truss head bolt on a lathe and turn down to 1/4 leaving 5/8” of the 5/16” portion then thread to 1/4-20. That’s how I make them. Time consuming but part of it
Old 02-15-2026, 07:24 PM   #11
Graham Freeman
I could supply you with some used ones at no cost.
Just pay the postage however i am in New Zealand.
Graham Freeman is offline   Reply With Quote
Old 02-16-2026, 10:00 AM   #12
Vanspeed
Vanspeed's Avatar
Thanks guys. I did get a pm from a member who thinks he has some. I appreciate the help.
Old 02-16-2026, 11:01 AM   #13
Bob NH
Bob NH's Avatar
Pretty sure I have a bunch of those, I had 3 35 pickups with leftover stuff.
Bob NH is offline   Reply With Quote
Old 02-17-2026, 05:50 PM   #14
BoxCar Tom
BoxCar Tom's Avatar
# B-35362, B part number? 32 part number? not used on a 32?
BoxCar Tom is offline   Reply With Quote
Old 02-17-2026, 08:03 PM   #15
Vanspeed
Vanspeed's Avatar
Sent you a pm.
Old 02-18-2026, 09:09 PM   #16
Model51
Model51's Avatar
BoxCat Tom - The "B-" prefix indicates the part first came out for a Model B vehicle. If the part didn't change the part number doesn't change. I think this particular part was phased out with the push-pin style some time in 1935, but the phase in of the newer style probably varied by production location and the old versions could always be substituted for the new ones some time after the vehicle rolled off the assembly line.
Hope this explanation makes sense.
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 02-18-2026, 10:27 PM   #17
35fordtn
35fordtn's Avatar
In terms of pass cars they were used 1932-34 and early 1935.
Old 02-19-2026, 11:31 AM   #18
Model51
Model51's Avatar
I believe the usage 35Fordtn gave about cars is the same for the commercial and truck vehicles too.
Old 02-20-2026, 01:49 PM   #19
Bob NH
Bob NH's Avatar
? ? ? I said I thought I had a few of those bolts, A guy on here responded and I have tried twice to get a message to him and he will not reply back ? So, if anyone needs some I have 23 in pretty good condition. $ 1.00 ea. plus a ride seems reasonable to me.
Old 02-21-2026, 08:11 PM   #20
Bob NH
Bob NH's Avatar
Vanspeed please send me a message using my email, not sure why we are having trouble ? [email protected]
