Old 01-23-2026, 05:11 PM   #1
[email protected]
johnr9q@yahoo.com's Avatar
Default Other Side Of My Drum
Is it steel or cast?
1931 Model A Ford Slant Window
johnr9q@yahoo.com is offline   Reply With Quote
Old 01-23-2026, 05:19 PM   #2
mleder
Default Re: Other Side Of My Drum
take the photo differently, if the drum were to be mounted to the car, take a photo of the edge in the vertical plane. One photo straight at the edge, one photo slightly angled to right one phot to the left so we can see the curve of the edge.
mleder is offline   Reply With Quote
Old 01-24-2026, 01:51 PM   #3
ModelA29
ModelA29's Avatar
The steel drum pictured has a rolled edge with a gutter (if you will) around it. On a cast iron drum the area is filled.
ModelA29 is offline   Reply With Quote
Old 01-24-2026, 03:26 PM   #4
BlueSunoco
Is it possible to tap that with a wrench and tell by the 'sound'?
Steel will make a high pitched ring cast iron will make a lower pitched sound??
Seems like an old time mechanic told me that in the early 70's......
BlueSunoco is offline   Reply With Quote
Old 01-24-2026, 03:38 PM   #5
Big hammer
Yes if you have been around both ! A novice novices probably not !
get a bigger hammer tap done
Old 01-24-2026, 06:08 PM   #6
jw hash
jw hash's Avatar
it IS a cast iron drum. you need to find someone with a drum gauge and measure the drum. you might get away with just having it turned.
jw hash is offline   Reply With Quote
Old 01-24-2026, 07:49 PM   #7
nkaminar
nkaminar's Avatar
JW, Steel. It has a large ring shrunk onto the drum which makes it look somewhat like a cast drum.
Old 01-25-2026, 09:28 AM   #8
J Franklin
J Franklin's Avatar
the person that has a drum gauge will know if it is CI or steel.
