Other Side Of My Drum 1 Attachment(s)
Is it steel or cast?
Re: Other Side Of My Drum take the photo differently, if the drum were to be mounted to the car, take a photo of the edge in the vertical plane. One photo straight at the edge, one photo slightly angled to right one phot to the left so we can see the curve of the edge.
Re: Other Side Of My Drum 1 Attachment(s)
The steel drum pictured has a rolled edge with a gutter (if you will) around it. On a cast iron drum the area is filled.
Re: Other Side Of My Drum Is it possible to tap that with a wrench and tell by the 'sound'?
Steel will make a high pitched ring cast iron will make a lower pitched sound?? Seems like an old time mechanic told me that in the early 70's...... |
Re: Other Side Of My Drum Yes if you have been around both ! A novice novices probably not !
Re: Other Side Of My Drum it IS a cast iron drum. you need to find someone with a drum gauge and measure the drum. you might get away with just having it turned.
Re: Other Side Of My Drum JW, Steel. It has a large ring shrunk onto the drum which makes it look somewhat like a cast drum.
Re: Other Side Of My Drum the person that has a drum gauge will know if it is CI or steel.
| All times are GMT -5. The time now is 03:01 AM. |
