Old 01-04-2026, 05:52 PM   #21
cadillac512
cadillac512's Avatar
Default Re: Adjusting Anti-Chatter Rods
Originally Posted by Fredy Decker View Post
I want to temporarily remove the anti chatter rods on my 1940 for cleaning and repainting however they are attached to the frame with FEMALE square headed bolts. A 3/8" ratchet is to big and a 1/4" is too small. Any advise?
https://www.grainger.com/product/GRE...-Socket-51PH15
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 01-04-2026, 06:16 PM   #22
deuce_roadster
deuce_roadster's Avatar
I hope most of you know what the purpose of the engine stay rods is. Ford engineers realized that with the transverse rear spring the torque tube style rear end, when you begin to move forward, the rear end rocks slightly forward pushes forward on the transmission and thus the engine. To prevent this action, they put the engine stay rods on that bolt solid to the frame and engine block. They have nothing to do with preventing clutch chatter. When Ford went to an open driveline with 2 parallel rear springs there was no longer any need for them. Someone somewhere thought they were to prevent clutch chatter and the myth began.
Old 01-04-2026, 06:28 PM   #23
petehoovie
petehoovie's Avatar
Great explanation, Deuce!...
Old 01-04-2026, 06:38 PM   #24
Kube
Super Moderator
Kube's Avatar
Spot on my dear friend. spot on!
Old 01-04-2026, 06:40 PM   #25
Kube
Super Moderator
Kube's Avatar
Originally Posted by deuce lover View Post
I believe it is a 5/16 " square opening.
That is correct.
Old 01-04-2026, 11:28 PM   #26
tubman
tubman's Avatar
Very true. I think the term was invented by the first guy that left them out after an engine swap. Hurst even offered some pre-load doohickies that were supposed to substitute for them with their engine mount kits for early Fords. They didn't.
Old 01-05-2026, 07:47 AM   #27
marko39
i used a piece of key stock to fit and an open end wrench.
marko39 is offline   Reply With Quote
Old 01-05-2026, 10:14 AM   #28
kurt v
What MARKO said plus heat, they are tight.
kurt
kurt v is offline   Reply With Quote
Old 01-05-2026, 03:30 PM   #29
glennpm
glennpm's Avatar
Originally Posted by glennpm View Post
Sacrifice a 3/8" short extension or 1/2" to 3/8" adapter. Measure the hole and grind the 3/8" extension or adapter to fit. Now you have a new tool for your box :-)
Drain plug 8mm and 5/16" square
https://tinyurl.com/bdmjwedk
https://tinyurl.com/2868tpy3
https://bcfasteners.com/shop/jet-h37...n-plug-socket/
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 01-05-2026, 03:51 PM   #30
tubman
tubman's Avatar
At those prices, I think "Kube" is right; make your own.
The icing on the cake is that Amazon lists a 3/8" drive 3/8" square drain plug socket for $11.82.
Old 01-05-2026, 06:07 PM   #31
19Fordy
19Fordy's Avatar
Here's some info. on aftermarket anti-chatter rods.
https://www.fordbarn.com/forum/showt...ds+aftermarket
Old 01-07-2026, 01:08 AM   #32
richard crow
they have nothing to do with clutch chater they are eng stay rods on a torque tube drive they hold the eng in place as the rear pusheses the car
richard crow is offline   Reply With Quote
Old 01-07-2026, 08:50 AM   #33
glennpm
glennpm's Avatar
https://www.earlyfordv8.org/forum/vi...ywords=chatter
"I agree with 42. All of the old Fords I've owned had some clutch chatter, some more than others. The Ford drive line went basically unchanged from the beginning thru 1948, mostly due to Henry's rigid opposition to change. As said, the problem arises as the rear axle pushes forward on the torque tube, leaving the motor mounts to absorb the thrust. [Pulls when gong into reverse and pushes when going forward] It is tempting to blame the clutch, itself, for the problem, but there are other factors to consider. The rear spring must be intact, with clips in place, and firmly attached to the crossmember. The spring shackles must have pins with little or no play. The rear hubs must be tight on the tapers. If you hear a "clunk" as you drive, check them. The u-joint housing must be tightened over the ball, with the cork seals in place. Lastly, the clutch release linkage and clutch housing bushings must be free of play. One end is attached to the frame, with the other end at the release shaft thru the bell housing. Any movement of the drive train is magnified by the linkage. The arm on the release shaft moves a fraction of the pedal travel, and as the engine moves on its mounts, this is translated into an irregular operation of the pressure plate, causing much of the "shudder". Lots of remedies have been tried. I've attached one such. None will remove all the problem, but you can reduce it to a tolerable level."
"One approach that I didn't include in my previous post is that sometimes the chatter, particularly if severe, can be reduced by placing the car on sturdy stands with all four wheels off the ground, then loosening the bolts that attach the transmission to the engine. After starting the engine and placing the transmission in gear, let it run a bit, work the clutch a few times, then cinch down the bolts. This will often reduce any mismatch between the center line of the transmission and the pilot bearing in the flywheel. Just be very careful when working under a car on stands, particularly when it is running. I prefer to do it with the car on a hoist in the shop, of course."
https://www.fordbarn.com/forum/showp...0&postcount=22
"The torque tube design was primarily to function well in forward motion. When you operate the vehicle in reverse gear, the rear axle tries to pull the cup of the tube away from the ball cover of the transmission. It can't move a lot unless there is wear on the components. The chatter rods weren't designed to help hold anything but the engine & transmission. The chatter might be the tube against the ball cover or as was said, a U-joint used to moving in forward motion may not work as well in reverse motion.
The same may hold true for the clutch plate & cover that are worn more with forward lock up but not so much with reverse motion. Wear patterns on flywheels & clutch plates can be pretty interesting to look at depending on how easy or hard the operator is on them."
https://www.fordbarn.com/forum/showp...3&postcount=23
"You can chatter about the steady rods importance but most likely the chatter is due to the incorrect pedal throw or poor clutch pedal adjustment. If you have changed the engine combination , trans combination or made a pedal arrangement that does not use the parts that were designed for the vehicle, the pedal ratio or free play adjustment is incorrect. Second place to look has been brought up and that is poor or loose rear engine mount cushions."
AI generated response, [URL=https://tinyurl.com/msdr9ete[/URL]
"Ford employed this [transverse springs with torque tube] design in its vehicles up through 1948, primarily due to the use of transverse leaf springs that could not withstand the forward thrust forces generated during acceleration.
The system was later abandoned with the introduction of the "new Ford" in 1948, which adopted a Hotchkiss-type rear axle with parallel springs at the rear and independent coils at the front.
Other manufacturers, including Buick, Nash, American Motors (AMC), and later high-performance vehicles like the Porsche 924, 928, and C5/C6 Corvettes, also used variations of the torque tube design."
Rumble Seat’s Notes
Old 01-07-2026, 09:55 AM   #34
richard crow
back in the day when we did a clutch on a ford we always used a new clutch from ford, if you wanted chatter you bought a rebuilt.i have five fords none have chatter if i do a clutch today on an old ford i send it to fort whyne clutch co & have it rebuil dont buy a new one from them all the new clutches today are from china
Old 01-07-2026, 04:52 PM   #35
deuce_roadster
I thought someone here said Ft. Wayne wasn't doing clutches anymore, or the company was gone or bought out. Any recent info?
Old 01-07-2026, 05:01 PM   #36
petehoovie
petehoovie's Avatar
https://fortwayneclutch.com/
Specializing in clutch & driveline for all makes & models of auto, truck, tractor, agricultural, antique, high performance, industrial, obsolete!
Old 01-07-2026, 05:37 PM   #37
tubman
tubman's Avatar
Last time I talked to them was 3 or 4 years ago and they weren't taking 8BA clutch cores and wanted to sell me a new one made by "some guy named Wang Fu" (their words). I'd ask a few pointed questions before dealing with them.
I went elsewhere.
Old 01-07-2026, 09:01 PM   #38
Kube
Super Moderator
Kube's Avatar
I went elsewhere.
Going elsewhere was a wise decision. Ft. Wayne was "the place" for many, many years. Not any longer.
I would not consider anything from them at this point.
Old 01-08-2026, 10:43 AM   #39
19Fordy
19Fordy's Avatar
I took a 3/8 square 3/8 extension and ground it down to 5/16 square to remove my anti-chatter rods.
