#21 |
In general Bronze will wear better, but Aluminum is good for many miles. It really depends on the alloys used for the Bronze and Aluminum.
#22 |
Werner, The advantage of a bronze bearing seal is that it has a thrust shoulder. If the thrust on the rear main is broken or cracked the aluminum seal can be replaced with the bronze seal and help prevent crank forward movement. The bronze is stronger than the type 11 babbitt I use. When doing a complete babbitt job I use them to take the stress of the other 3 thrust shoulders. I have successfully used them as a partial fix when a club member wants to keep his car on the road. Dan
#23 | |
"Bronze Rear Main Thrust Washer- USA made. Replaces the A6335 rear main seal. Gives the engine a better rear main thrust surface." dansluck, how do you even install that thing? Can he do it with the motor in the car? |
#24 | |
Yes, that would be very interesting to me as well. I found this video: https://www.youtube.com/watch?v=8MH3HtTnshQ. According to it, the installation only requires to remove the oil pan. If I understand correctly, that's related to the crescent-shaped sealing washer too. Dankeschön!
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
#25 |
Did you remember the gasket between the block and the flywheel housing?
Charlie Stephens |
#26 | |
The oil isn't dripping along the oil pan, but only from the clutch housing. - Has anyone ever done this repair from underneath with the engine still installed?
#27 |
I agree that if missing or gasket is damaged that this gasket will leak from bottom of flywheel housing AKA "clutch housing".
#28 | |
Benson, thanks, but I can not open the attachment.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version Last edited by Werner; 09-24-2025 at 04:31 AM. Reason: corr. |
#29 |
I had the leak between the flywheel housing and block that has been talked about. The only cure was to take the engine out, use a different flywheel housing that was flat, and put the gasket in with plenty of gasket cement. The oil was dripping from the bottom of the flywheel housing. In my case I had to take the exhaust manifold off to see the leak.
#30 |
Sometimes it helps to put fluorescent dye in the oil (or coolant) to trace a leak. You can see the leak with an ultraviolet light and trace it to it's source.
The Master Cylinder Enjoying life at the beach in SoCal... Last edited by The Master Cylinder; 09-23-2025 at 07:41 PM. |
#31 |
So what did you do to fix the Babbitted main cap? I am faced with a rear main cap almost the same. I’m hoping I can get a shop that can repour my lower cap half and mill it, fingers crossed!
#32 |
Since I planned on keeping this car and touring, I decided to pull the engine and have it completely rebuilt with inserts installed at the advice of my machinist because I don't want any (hopefully) issues down the road.
The Master Cylinder Enjoying life at the beach in SoCal... |
#33 | |
I haven't done this work yet. I've been a bit ill and can't lie under the car for long periods of time. But I took an oil sample, and spectral analysis didn't reveal any noticeably increased metal abrasion.
#34 |
When the bearing comes apart in chunks, like mine did, it may not show any metal abrasion!
The Master Cylinder Enjoying life at the beach in SoCal... Last edited by The Master Cylinder; 10-28-2025 at 02:17 PM. |
#35 |
Hallo und guten Abend.
I've only made a little progress. The two nuts on the rear bearing cap are so tight that I can't loosen them. I'll have to try it again with an impact wrench tomorrow. In the oil pan, I only found a little steel shaving, 3 x 2 mm and 0.05 mm thick. However, the aluminum camshaft gear was rubbing against the cork gasket that protrudes on the inside. Since the oil pan and filter screen were clean, the sludge is in the oil filter. A note for those who insist on using unalloyed motor oil: The picture shows how clean the oil pan and the intermediate plate are. They were only degreased with brake cleaner. I use exclusively 20W-50 HD Oil classified API SC. Bis morgen, beste Oelfinger Gruesse!
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version Last edited by Werner; 10-31-2025 at 04:05 PM. |
#36 |
Please don't use that blue silicone gasket sealer. I have seen way too many expensive engines ruined because of it. Although the Model A engine does not have a lot of oil passages, it does tend to plug things up.
#37 |
I agree.
Same problem with the orange silicone gasket sealer! More that a few times I have seen it plug up oil drain passages and oil drain pipe in rear main bearing caps especially when too much was used. Pieces of the silicone break loose and flow down passages and plug them up. Last edited by Benson; 11-01-2025 at 10:18 PM. |
#38 |
Yes well, thanks for the important/helpful information. That's thick "Hylomar H" what I use. It was also called "Rolls Royce Paste" 50 years ago. It stays soft.
What recommendations do you have, please? Dankeschoen!
#39 |
Werner , put a piece of pipe on your tool to break it loose https://youtu.be/8MH3HtTnshQ?si=5Cu0E0l7BJ8JgZsJ
#40 | |
Bitte sehr… |
| Thread Tools | |
| Display Modes | |
