Old 01-22-2025, 09:23 PM   #17
RGC1
Default Re: Things I should Know-long trip planned
Originally Posted by glennpm View Post
Just thinking of a few more items I carry with me. Two long lenghts of wire, red & black with aligator clips for testing or temporaily bypassing, Roll of 16 GA wire, wire strippers, splices terminal ends and a crimping tool. I also carry a good air compressor, not a cheap one, something that will fill your tire fairly quickly. I also carry a tire plug kit, razor blades and good pliers to pull screws and nails out of tires. If you now run tubes, get rid of them. You can seal the wire nipples inside the rims and give yourself the option of a roadside repair.
LED flashlight, Scissors jack and block of wood to put on the ground for the jack, complete tool set, fuses, duct tape, CS tie wire and a bunch of zip ties, can of starter fluid ...
Those all sound like good items to add to the list, I plan on buying new tires and was going to get some pointers there, but that is a pretty good idea never thought of that. Thanks !!!
RGC1 is offline   Reply With Quote
