Old 12-16-2024, 08:48 PM   #1
busmania
busmania's Avatar
Default Grease trans input shaft (the shaft in the clutch)?
I never really put grease on the trans shaft that slides into the clutch assembly. However I was watching a show on motor trend and he greased the very end, the part that goes into the pilot bearing. Should I grease this as well as the splines that slide into the clutch plate?
40 ford coupe Build -https://www.jalopyjournal.com/forum/...coupe.1277406/
busmania is offline   Reply With Quote
Old 12-16-2024, 09:39 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Grease trans input shaft (the shaft in the clutch)?
I do with a light chassis grease sparingly.
Old 12-16-2024, 11:59 PM   #3
cas3
Absolutely grease the splines on the trans input shaft. Not big gobs that will fly into the clutch, but a light smear on all surfaces to keep it from rusting up, or seize while in storage.
cas3 is online now   Reply With Quote
Old 12-17-2024, 12:23 AM   #4
Kurt in NJ
Kurt in NJ's Avatar
There is special grease for clutch splines .
It is available on amazon and some european auto parts sellers,Sachs brand and others
Old 12-17-2024, 12:38 AM   #5
cas3
I've always just used what ever was close by in my shop. Never had an issue. I have heard not to use anti seize from some pro mechanics Though, it gets dry and sticky.
Old 12-18-2024, 08:15 PM   #6
rotorwrench
rotorwrench's Avatar
Grease is good if a spline has to slide like on a drive shaft. Clutch disks and flywheels don't work if grease gets slung around in there. I would be sparing with anti seize too. Anti seize will keep fretting from going on between parts.
Old 12-19-2024, 08:23 AM   #7
Terry,OH
Terry,OH's Avatar
The clutch doesn't move on the splines of the transmission input shaft, but a small amount of grease will not hurt. I use synthetic grease on parts that can not be lubed after install.
Old 12-19-2024, 02:59 PM   #8
busmania
busmania's Avatar
I put a very small amount of lube on it. Almost back on the road!
