I'm looking for a someone reputable in San Diego to rebuild my carburetor. Does anyone know someone local that they could recommend?
Carburetor (3).jpg Carburetor (10).jpg |
I'd send it to Charlie Schwendler in New York. With "California Pricing" in effect, the shipping is probably a wash and he is quite simply the best.
Check with C&G Ford parts in Escondido. The surely will know of someone near you.
I recommend Charlie also, he’ll have your carb turned around in no time
Charlie NY, 1-716-662-9159. |
Super Moderator
The top casting is from a 91-99 and the center section is from a 59 if the Carb. is for your avatar suggest finding a 91-99 center section. Ask the rebuilder of your choice if they have one.
Yep; that high float vent does not like high fans. made for the crank mounted fans. Newc
#9 | |
Yes, it's for the fire engine that's my avatar. The carburetor is pieced from two different carbs? If it is, thanks for the heads up. I'm learning as I go. It appears either or after the Department of Defense auctioned it off, someone mixed and matched several parts on it. |
| Thread Tools | |
| Display Modes | |
