Old 08-26-2024, 03:21 PM   #21
Tim Ayers
Default Re: Flathead Build - Warning, Must Wear Eye Protection
Originally Posted by V8COOPMAN View Post
That would be hard to afford to do today, much less find a shop to do it correctly.
Coop
Coop,
The thing is, it is today and now. Follow NeilinCA's $4K 5 window build thread on the HAMB. If you think the motor is nice, wait until you see the rest of car and chassis.
Old 08-26-2024, 03:39 PM   #22
NealinCA
NealinCA's Avatar
Originally Posted by Tim Ayers View Post
Coop,
But a lot of the chrome on the engine, transmission and chassis is old chrome, parts that I found at swapmeets, etc already plated. I wouldn't and couldn't set out to do this today with all fresh plating.
NealinCA is offline   Reply With Quote
Old 08-26-2024, 05:20 PM   #23
Tim Ayers
Ah, right and good point. How much of the build would you say is new chrome?
Old 08-26-2024, 06:49 PM   #24
NealinCA
NealinCA's Avatar
Here's a run down of old and new plating
Engine:
Old Chrome - Starter, Generator, Idler assembly, fan, 97 carbs, air cleaners, fuel pump, fuel pump stand, oil filter housing
New Chrome - Water pumps, timing cover, motor mounts, plug wire conduits, oil pan, coil, headers
Transmission:
Old Chrome - Transmission case, Shift tower, shift lever, knob, clutch release arm
New Chrome - Rear mount, emergency brake handle and bracket
Front Suspension:
Old Chrome - Axle, wishbone, perches, spring, u-bolts and pad, backing plates, tie rod ends, steering box, pitman arm
New Chrome - Spindles, shackles, shock arms, dogbones, draglink, tierod
Rear Suspension:
Old Chrome - Spring, u-bolts
New Chrome - Axle bells, banjo, radius rods, torque tube, backing plates, shackles, shock links
Misc:
Old Chrome - Grille insert, BLC headlights, front spreader bar, hood latches, high crown baby moon hubcaps
New Chrome - Column tube, battery box, pedal assembly, throttle pedal, garnish moldings, windshield frame
Old 08-26-2024, 06:51 PM   #25
acchaplin
Originally Posted by TJ View Post
A lot of cool BLING!
I 2nd that! (expletives inserted here)
Like to see what buffers and wheels you use.
acchaplin is offline   Reply With Quote
Old 08-27-2024, 05:06 AM   #26
Tim Ayers
Engine:
Transmission:
Front Suspension:
Rear Suspension:
Misc:
Unreal, Neal. Like I said on the HAMB, this build is going into the history books as one of the nicest '32's ever built. The attention to detail is simply incredible.
Old 08-27-2024, 09:29 AM   #27
Lanny
Lanny's Avatar
The Old Chrome Coupe "SHOW TIME"
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 08-27-2024, 01:31 PM   #28
bcatcmc
bcatcmc's Avatar
very impressive !
bcatcmc is offline   Reply With Quote
Old 08-28-2024, 05:43 AM   #29
ford nut
ford nut's Avatar
as good as it gets.
ford nut is offline   Reply With Quote
Old 08-28-2024, 09:45 PM   #30
34pickup
34pickup's Avatar
Reminds me of looking through old 1960s Hot Rod magazines with everything chromed.
Ah, the good ole' days!
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 08-28-2024, 10:51 PM   #31
Dan McEachern
Nice! Ya gotta share your plater with us!
Dan McEachern is offline   Reply With Quote
