Old 05-14-2023, 08:38 PM   #1
1930artdeco
1930artdeco's Avatar
Default Tranny cooling line issue
So I ordered tranny cooling lines and they fit great except for one small issue. How do I fix this? I guess it is better to be too long than short. I was thinking of cutting the flare off and adding a 90* elbow to go into the tranny and then reflare the tubing. Will that work?
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 05-14-2023, 08:58 PM   #2
miker98038
miker98038's Avatar
Default Re: Tranny cooling line issue
Picture would help.
miker98038 is offline   Reply With Quote
Old 05-14-2023, 09:35 PM   #3
1930artdeco
Crap- I thought I attached it, apparently I didn’t . Here you go.
1957 Country Sedan
Old 05-15-2023, 10:29 AM   #4
Ole Don
Ole Don's Avatar
Yes, you can shorten that and reflare. You may have to rent a double flare tool from one of the parts houses, but if you get it back soon, they will usually give your check back to you.
Ole Don is offline   Reply With Quote
Old 05-15-2023, 10:42 AM   #5
miker98038
miker98038's Avatar
You might see if they’ve got a small “plier style” bender for rent too. From the looks it’ll be flare first, then bend. Hard to tell from a picture.
Old 05-15-2023, 11:49 AM   #6
evintho
evintho's Avatar
It might be the picture but, it doesn't look like you have much distance to cover there. The trans lines are long and can easily be bent somewhere near the middle to compensate for that distance so the line will insert and the fitting can be screwed in. If you ordered the correct lines for your car, they should fit with a bit of manipulation.
In my '54, 5.0/AOD I used the factory Mustang lines and had to tweak them a bit cuz the radiator was moved forward a few inches. Just be careful when manipulating the lines.
evintho is offline   Reply With Quote
Old 05-15-2023, 03:30 PM   #7
rotorwrench
rotorwrench's Avatar
A person can bend a joggle into a long straight section and take up a good bit of length. When it's close, the fitting end may just need a small amount of tweeking to get it to align and screw on. I've had a double flare set for years. The set used to be affordable but I haven't had a need to check for many years so I don't know what they cost now.
