Old 12-13-2022, 01:40 PM   #41
KiWinUS
KiWinUS's Avatar
Default Re: '36 221 - rebuildable??
Too late now but the grill can stay in.
KiWinUS is online now   Reply With Quote
Old 12-13-2022, 01:41 PM   #42
40 Deluxe
Originally Posted by jimTN View Post
Its hard to tell from the pics but most of those engines had sleeves. The easiest way to work that bad cyl may be to break the piston out driving from below, worst case cutting the rod into, then -putting a sleeve in that cyl bored to match what you bore the other cyl's. As wore as the engine is I would suspect it will need boring all cyls.
DO NOT damage the rod if at all possible! They are weight matched as a set at the factory so keep all eight together. Kill the piston instead. The rod bearings are full floating so are subject to wear on both surfaces. The bearings are available in various combinations of oversize outer diameters (the rod is bored/honed oversize to match) and undersize inside diameters (to fit a reground crankshaft). The flanged rod bearings are on ebay in various sizes. Get everything measured before ordering bearings. It's amazing how well these full floaters hold up. You may not even need new ones.
Old 12-13-2022, 02:00 PM   #43
sjaakslinger
sjaakslinger's Avatar
Thanks, but it needed some attention anyway.
Verstuurd vanaf mijn SM-G781B met Tapatalk
sjaakslinger is offline   Reply With Quote
Old 12-13-2022, 02:03 PM   #44
sjaakslinger
Thanks. Besides the rods, what else? I suppose the valves and springs would need replacing anyways?
Old 12-13-2022, 02:28 PM   #45
tubman
tubman's Avatar
Some of the valve train components are bound to be damaged on removal in an engine like this. The later (non-mushroom stem valves and related) parts from an 8BA type engine are easier to get, easier to work with, and easier to pay for (at least here in the states).
Old 12-14-2022, 01:04 AM   #46
sjaakslinger
Do those later non-mushroom types fit in my 36 engine?
Old 12-14-2022, 04:44 AM   #47
Mart
Mart's Avatar
Yes.
Old 12-14-2022, 07:58 AM   #48
sjaakslinger
Thanks. Trying to figure out which parts of the engine I should definately safe and which can/should be replaced.
Old 12-14-2022, 08:54 AM   #49
sugarmaker
sugarmaker's Avatar
Your doing good! That bad boy needs to come out! It looks like it will need LOTS of love!
Get a engine lifter hooked on to that where mart points and pick that engine out.
Looking forward to your next steps! Good pictures by the way!
Regards,
Chris
1932 AAB Truck
1953 Ford Jubilee
1965 Mercury Comet Caliente
1966 Ford F100
2015 Ford F250 SuperCrew
Lots of Allis tractors
Some Cub Cadets
Old 12-14-2022, 09:22 AM   #50
Mart
Mart's Avatar
Don't rule out being able to source a replacement motor. There are French and German flatheads, all of which could be made to work in your car. Plus there were a lot of USA cars in Holland back in the day. Do you know anyone in Holland into hot rods? They might have leads on motors. I know a couple of people in Holland.
Old 12-14-2022, 12:58 PM   #51
AZ34
Reposted in a new thread.
AZ34 is offline   Reply With Quote
Old 12-14-2022, 02:38 PM   #52
sjaakslinger
No, I don't know any 'flathead people' here. If my engine isn't a rebuild candidate, I have to really think it over about the car. Too many other car projects to go crazy on the Ford. Maybe if I sell another car... But I'm not there yet.[emoji16]
Still moderately positive about the engine. Hoping to pull it tomorrow and check it out more. Especially the main bearings.
Old 12-15-2022, 03:31 PM   #53
sjaakslinger
Got the engine out. Went pretty ok. Wasn't sure about those 2 horizontal rods coming from the frame going through the sides of the bell housing. We pulled the engine forward and got it all clear.
Next will be finding the proper way to mount the engine on an engine stand. If anyone has some pictures of what they use, it would be appreciated.
Not so nice was to find out the left front took a hit at some point. That crossmember/bar between the front wheels has a bend. [emoji19] I'll post some pics and questions in a new thread.
Dennis
I think the car looks a bit like a toothless grandma now....
Old 12-15-2022, 06:29 PM   #54
cas3
The side of the block where the exhaust ports are is a 45% angle. Just use a manifold for a bolt pattern, and cut a tube that fits your engine stand at 45% and weld it up. Note the front two bolts are bigger
Old 01-02-2023, 11:04 AM   #55
sjaakslinger
We're working on a plate to mount the engine stand on the exhaust manifold port. Would a 5mm/1/5 inch plate be thick enough?
Dennis
Old 01-02-2023, 02:25 PM   #56
frnkeore
frnkeore's Avatar
6mm would be better but, I think 5mm will work fine.
Frank
'35 Ford Model 51
'48 Ford F3
'54 Ford Tudor Mainline
frnkeore is offline   Reply With Quote
Old 01-02-2023, 02:52 PM   #57
Mart
Mart's Avatar
No You want at least 8mm.
Old 01-02-2023, 03:44 PM   #58
sjaakslinger
Ok, so I guess 2 of them together to be sure.
Old 01-02-2023, 03:51 PM   #59
bobH
I don't 'speak-mm', so I converted from 3/8 and came up with something a little heavier that what Mart posted. So, as post 58 suggests, I'd go with the two. But, from my perspective, being old and lazy, I'd BUY a mount... previously discussed and posted here on the barn. (obviously, just opinion)
bobH is offline   Reply With Quote
Old 01-02-2023, 04:00 PM   #60
Mart
Mart's Avatar
8mm is 5/16" and 3/8 is just a bit less than 10mm.
