Old 06-03-2010, 06:27 PM   #1
Ol' Ron
Ol' Ron's Avatar
Default Fuel pump pushrod
How much travel does the fuelpunp push rod have?
Old 06-03-2010, 06:48 PM   #2
36 coupe
Banned
Default Re: Fuel pump pushrod
About 3/10 of an inch.Never found one with excess wear.
36 coupe is offline   Reply With Quote
Old 06-03-2010, 07:20 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
Measured a used 8BA cam (on V-blocks with dial indicator)
The pushrod lobe has .178" of travel.
Old 06-03-2010, 08:23 PM   #4
1oldtimer
1oldtimer's Avatar
i have a tool to measure it, i'll look for it.
1oldtimer is offline   Reply With Quote
Old 06-03-2010, 09:27 PM   #5
jdl
jdl's Avatar
Send a message via ICQ to jdl
It is,,, .185 minimum .200 maximum Ford specs. This is for 8BA, there are ways around this of course, use a longer or shorter pushrod, use a thinner or thicker gasket under the fuel pump mount.
jdl is offline   Reply With Quote
Old 06-03-2010, 10:07 PM   #6
James
Don't you think the travel of the rod is entirely dependant on the lift of the cam lobe? Changing the relative difference between the top of the rod and the fuel pump lever relates to the degree of interaction between the rod and the lever.
James is offline   Reply With Quote
Old 06-04-2010, 05:53 AM   #7
51 MERC-CT
51 MERC-CT's Avatar
Originally Posted by james View Post
don't you think the travel of the rod is entirely dependant on the lift of the cam lobe? Changing the relative difference between the top of the rod and the fuel pump lever relates to the degree of interaction between the rod and the lever.
right on ( jdl - take note )
Old 06-04-2010, 06:50 AM   #8
jdl
jdl's Avatar
.185 to .200 is the lift of the pushrod. if your cam ecentric is worn down you will have less lift, therefore your fuel pump lever may not acuate enough to properly pump gas. if you add lenghth to the push rod with say a washer, now your pump may work. this is done quite often. you can acomplish the same goal by lowering the fuel pump mount. Most flathead guys know this trick already. Geez!!
p.s I am not as dumb as I look...jdl
The correct lift is .185 to .200
Old 06-04-2010, 08:06 AM   #9
flathead4rd
flathead4rd's Avatar
WOW! Is this site turning into the HAMB all ready?
flathead4rd is offline   Reply With Quote
Old 06-04-2010, 08:22 AM   #10
Ol' Ron
Ol' Ron's Avatar
Thanks guys, didn't mean to cause any trouble.
Old 06-04-2010, 08:28 AM   #11
jdl
jdl's Avatar
Hey Ron, no problem here, I am very easy to get along with, I have a great deal of respect for the Fordbarn guys, I value your advice and years of knowledge, I enjoy reading you posts, keep up the good work.
jdl
