How much travel does the fuelpunp push rod have?
Banned
About 3/10 of an inch.Never found one with excess wear.
Measured a used 8BA cam (on V-blocks with dial indicator)
The pushrod lobe has .178" of travel.
i have a tool to measure it, i'll look for it.
It is,,, .185 minimum .200 maximum Ford specs. This is for 8BA, there are ways around this of course, use a longer or shorter pushrod, use a thinner or thicker gasket under the fuel pump mount.
#7 | |
( jdl - take note )
.185 to .200 is the lift of the pushrod. if your cam ecentric is worn down you will have less lift, therefore your fuel pump lever may not acuate enough to properly pump gas. if you add lenghth to the push rod with say a washer, now your pump may work. this is done quite often. you can acomplish the same goal by lowering the fuel pump mount. Most flathead guys know this trick already. Geez!!
p.s I am not as dumb as I look...jdl The correct lift is .185 to .200 |
WOW! Is this site turning into the HAMB all ready?
Thanks guys, didn't mean to cause any trouble.
Hey Ron, no problem here, I am very easy to get along with, I have a great deal of respect for the Fordbarn guys, I value your advice and years of knowledge, I enjoy reading you posts, keep up the good work.
jdl |
| Thread Tools | |
| Display Modes | |
