Old 06-13-2022, 10:32 PM   #1
Lamar Green
Default What weight oil do you use in transmission and rear end
Hey Guys,
What weight gear oil are you running in your transmission and rear end gear boxes?
Lamar Green is offline   Reply With Quote
Old 06-13-2022, 10:47 PM   #2
Gary WA
Gary WA's Avatar
Default Re: What weight oil do you use in transmission and rear end
600w from Model A vendors,Others will have different oils
www.whidbeymodelaclub.com
Old 06-14-2022, 05:02 AM   #3
bavArian
bavArian's Avatar
SAE 250 GL1/2 from a German brand. (Rektol Klassik)
Using it for gearbox, differential and steering box. No complaints.
bavArian is offline   Reply With Quote
Old 06-14-2022, 05:31 AM   #4
Patrick L.
Patrick L.'s Avatar
Either 140 or 250 in transmitter, steering box. Anything from 80-250 [ or 600W] in the rear.
Old 06-14-2022, 05:38 AM   #5
lotsagas4u
Stalube 140 gear oil
lotsagas4u is offline   Reply With Quote
Old 06-14-2022, 06:22 AM   #6
nkaminar
nkaminar's Avatar
90W-140 G5. Modern oils have wear reducing additives.
Old 06-14-2022, 12:10 PM   #7
Bob Bidonde
Bob Bidonde's Avatar
I use SAE 85W140 GL5 Super Tech Gear Oil from Walmart in the transmission and differential.
Bob Bidonde
Old 06-15-2022, 05:47 AM   #8
Patrick L.
Patrick L.'s Avatar
You could try a lighter weight oil in the transmission, I just find that I don't like the way it shifts.
Old 06-15-2022, 07:01 AM   #9
Redbird
Redbird's Avatar
Bert's Model A.
Redbird is offline   Reply With Quote
Old 06-15-2022, 10:06 AM   #10
Anteek29
Anteek29's Avatar
Stalube 140 Gear Oil
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 06-18-2022, 01:51 PM   #11
Sunny the Model A
Sunny the Model A's Avatar
600w steam cylinder oil. exact same stuff the model a suppliers sell, so I get it in 5-gallon buckets. no complaints except my diff is weeping oil from the bottom. no biggie, just got to keep an eye on it.
"Ain't but three thangs in this world worth a solitary dime, but A Models, Sweet Tea, and Macaroni Pie!"
Sunny the Model A is offline   Reply With Quote
Old 06-20-2022, 07:14 AM   #12
Kevin in NJ
That is not the weight of the oil but a type of oil.
Back in the 30's it was call 600W and is just a heavy pressure steam oil designed for straight cut gears. Today it has a different reference but people have researched the current naming.
https://www.vintagefordforum.net/for...il-information
Old 06-20-2022, 04:24 PM   #13
Patrick L.
Patrick L.'s Avatar
Yep, 600W is a designation for the old steam cylinder oil. It works out to about 180-240 weight.
Old 06-20-2022, 10:06 PM   #14
eagle
eagle's Avatar
This is what I use: https://lucasoil.com/products/engine...oil-stabilizer It makes a huge improvement in tranny feel. Smoother shifts, slick feel to shifting, quiets gear noise. I've had it in my A tranny for years now, no comparison to the vendor 600W sludge.
Old 06-21-2022, 07:01 AM   #15
LLB
eagle, Do you use that product straight or blended with something else?
LLB is offline   Reply With Quote
Old 06-21-2022, 07:25 AM   #16
WHN
I have been using a mix of 50% 600W oil and 50% STP. No leaks, shifting is great, works for me.
Enjoy.
