Old 04-11-2022, 04:51 PM   #1
Colonel
Default Car Tie Down in Trailer
Have an enclosed car hauler. I tie down the car on four corners to the D rings but still experience movement of the car sideways in the trailer. What can I do to prevent this? All ideas and pictures appreciated.
Colonel is offline   Reply With Quote
Old 04-11-2022, 05:22 PM   #2
Dave in Petaluma
Dave in Petaluma's Avatar
Default Re: Car Tie Down in Trailer
Let some air out of the tires. I know it sounds lame, but it works.
Dave in Petaluma is offline   Reply With Quote
Old 04-11-2022, 06:39 PM   #3
Big hammer
How are you attaching the tie downs to your car? hopefully not to the bumper’s or frame! I crisis cross the front and straight back on the rears attached to the axles. Some use two straps on each corner crisscross and straight!
get a bigger hammer tap done
Old 04-11-2022, 08:49 PM   #4
Harpkatt
Harpkatt's Avatar
Are the straps on the wheels? That's where they should be. If they're tight at all 4 it shouldn't move. DOT technically requires 4 straps and 2 safety chains as I recall. I've never seen it done correctly by and AAA tow operators.
Harpkatt is offline   Reply With Quote
Old 04-12-2022, 03:40 PM   #5
Redbird
Redbird's Avatar
Install the floor rail system with webs that go over the tires. It will never move!
Redbird is offline   Reply With Quote
Old 04-12-2022, 04:17 PM   #6
ronn
the reason you experience movement is because you are not tied diagonally.
this was once discussed here int he past, with guys swearing they could just tie off at each corner.
well your experience has shown otherwise......
Old 04-13-2022, 10:06 AM   #7
burner31
burner31's Avatar
Whenever I trailer any of my cars I use the wheel straps, of course in a enclosed trailer it may be a bit of a struggle to get them on/off
Keith
Shawnee OK
'31 SW 160-B
Old 04-13-2022, 10:10 AM   #8
ronn
Why did the Titanic sink?
EXACTLY & discussed ad nauseam!
LOL
Old 04-13-2022, 12:55 PM   #9
Tobey
I'll third the use of wheel nets. I put down E Track so I can move the attachment points as needed.
Tobey is offline   Reply With Quote
Old 04-13-2022, 06:12 PM   #10
Ayers1
Ayers1's Avatar
I have an open trailer but I always use the criss-cross method and haven't had any issues.
Ayers1 is offline   Reply With Quote
