Old 03-16-2022, 06:32 PM   #1
bosticjb
Default Fan Blade Nut
When you replace the fan how much should you tighten the nut and is there a torque spec
bosticjb is offline   Reply With Quote
Old 03-16-2022, 07:59 PM   #2
Gene F
Gene F's Avatar
Default Re: Fan Blade Nut
My experience is that the first time you tighten it, the next day after a short spin it will require retightening.
Old 03-16-2022, 09:27 PM   #3
mleder
Hopefully it is a reproduction style that is aluminum. With that said you should place a steel washer under the castle nut. If you don't it will loosen. Grab the fan and try to shake it before starting when you check under the hood. This is a good safety check to see if it is loose. Be safe not sorry. Do this often
mleder is offline   Reply With Quote
Old 03-17-2022, 04:20 AM   #4
johnbuckley
johnbuckley's Avatar
I agree... check it each time after the first three drives
Old 03-17-2022, 05:25 PM   #5
bosticjb
Thanks
Old 03-18-2022, 06:24 PM   #6
jrelliott
jrelliott's Avatar
When installing the fan on the water pump shaft, drop the opposite end of the water pump shaft a couple of times on something hard like on the flat spot surface on the top of a vice with the fan snug on the shaft to seat it good. Then place the steel washer under the castelated nut and tighten snuggly. Do not back off to get the holes to line up, but tighten.
Old 03-19-2022, 09:22 AM   #7
JBill
If the "look" doesn't bother you, consider a six-blade plastic fan.
JBill is offline   Reply With Quote
