#21 |
Labor is money too. The older you get the more time has an affect. I love to fab stuff but I've learned to balance my time a lot better on projects and especially if someone else can do it cheaper than I can. My time gets more valuable every year.
#22 |
Exactly how bad is the bumpsteer with flipped uprights and the steering arms not heated and bent down?
#23 | |
The factory bumpsteer will still be present unless a bumpsteer kit that moves the inner tyrod ends forward is installed.
#24 |
Is this the kit offered by Jamco?
I went, I saw, I bought the T shirt 51 Ford Deluxe Tudor 32 Ford roadster 39 Mercury Towncar |
#25 |
Have no idea but it is like the one that I installed many years ago made by Fatman. (the Jamco one may be made by Fatman)
#26 | |
Yes, you are correct in that Fatman makes that kit. Having this setup on your car for some years, I take it you felt it worked/was worth it? Thank you.
#27 |
If you know what bumpsteer is and have experienced it then the kit works and to me has been worth it.
#28 |
knock the rivets out of the lower control arm, spring mounts, put a one inch spacer in, replace the stock bolts with grade 8 she'll be low. And it is totally reversable and easy. The lowering block can be aluminum or steel, 1" by 1 1/4" , kinda old fashion but it works.
#29 | |
#30 | |
I am well aware of what bumpsteer is. Based on your answer I will keep this setup on the "to do list" for my '51.
| Thread Tools | |
| Display Modes | |
