Question:
The battery in my 37 Ford is a show battery with Ford logo. It doesn’t have cells, but an electronic apparatus. It is constantly running down. I recharge it with a 6 volt charger, but it reads 8 plus volts. Question: Has anyone seen a battery like this? Do you have to have a special charger for it? Your help will be greatly appreciated. Thanks. |
You may have an Optima in an original case. Why is it running down? If it is disconnected and running down you may need a new one. If it is connected and running down it may be time for a new battery.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
If it is installed in the car and running down then it sounds a little like a "phantom" or parasitic load. A defective alternator would be one area to explore. We're making further assumptions. Until we know what you have we can only guess. A generator charging system? A stuck cutout relay works well to cause trouble.
Post some pictures of your battery, I mounted a cutoff switch under my dash.
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
| Thread Tools | |
| Display Modes | |
