I lapped in my kingpin and pedal bushings. Grease goes into them but I really have to crank on the grease gun. Is this a problem?
Don't never get rid of nuthin! |
do your bushings have spirals cut into them? if so then no, if not then yes
I did read about using a heat gun to get the area warm so the grease will flow easier.
Had a project 54 Chevy. Couldn’t get the front zerts to take grease. Warmed them up with a small benzene torch. Worked great. Pushed some really old grease right out.
Get the wheels off the ground for the king pins that helps.
Super Moderator
Yes sir! ALWAYS remove the weight from the spindle pins when attempting to grease.
Or 5 more seconds with the slotted dowel and 120 grit.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
the bushing next to the thrust bearing should have a passage that goes to the bearing that should take grease easilly and show excess around the thrust bearing
I took the pedals out and put a small burr into the Dremel. I cut some shallow grooves out from the hole for the fitting, put a fresh tube of grease with Moly in the gun and it went in very nicely. Thanks guys!
As an aside, the grease that was in the gun had been leaking oil out for sometime and it was around freezing this morning when I started. It was hard as could be. Should I start with a fresh tube if the grease has been sitting for a long time and has left a puddle?
| Thread Tools | |
| Display Modes | |
