Old 10-13-2021, 03:49 PM   #1
mclark12
Default 1934 Radiator hose fittings
Does anyone know where I can find a couple of brass fittings to install mechanical water temp bulbs in the upper radiator hoses on a stock 1934? They seem a bit hard to find.
Thanks
mclark12 is offline   Reply With Quote
Old 10-13-2021, 04:28 PM   #2
petehoovie
petehoovie's Avatar
Default Re: 1934 Radiator hose fittings
Talk to this guy > Robert Shewman, POB 163, Kimberton PA 19442 Tel. 610-933-6637 or email [email protected]
Old 10-13-2021, 06:44 PM   #3
mclark12
Thanks, I’ll contact him.
Old 10-14-2021, 12:44 AM   #4
deuce lover
deuce lover's Avatar
If you mean to connect an original dual-temp gauge- they are next to impossible to find.It been discussed here before.Last repo's made were in the 1980's.
Old 10-14-2021, 01:16 AM   #5
koates
What some have done including me is to fit the later 1936 water pumps which have an inbuilt fitting in their body casting so that you can fit your temp sender in there and not in the hose. Some new pumps are available which have improved modern bearings and seals and improved impellers for better cooling. Check them out from Bob Drake, C&G Ford parts, Macs and some other dealers. Regards, Kevin.
koates is offline   Reply With Quote
Old 10-14-2021, 01:54 AM   #6
V8COOPMAN
V8COOPMAN's Avatar
This Bob Shewman stuff ABOVE has nothing to do with bulb wells like the OP is referencing.
Click the link BELOW for quite a few examples of different thermostat bulb wells that are available. DD
https://www.bing.com/shop?q=temperat...75298F04F0DDB7
Click Links Below __
T5 W/TORQUE TUBE
Old 10-14-2021, 03:37 AM   #7
deuce lover
If he has the orig 33-34 dualtemp the nut at the bulb has female threads.It won't work in that port of the '35-'36 w/pump .An adapter will have to be made.
Old 10-14-2021, 08:48 AM   #8
mclark12
Thanks for the feedback. More than likely I’ll have to install “36” pumps so I can install Stewart-Warner mechanical water temp gauges.
Old 10-15-2021, 07:34 AM   #9
deuce lover
If you have or are using the original spark plug wire tubes - on the right side it might be a tight fit to install that sender.
Old 10-15-2021, 07:39 AM   #10
koates
Nope, the sender will just fit into the right side pump. Its close. Regards, Kevin.
