The Ford Barn
-   -   1934 Radiator hose fittings (https://www.fordbarn.com/forum/showthread.php?t=305144)
mclark12 10-13-2021 03:49 PM
Does anyone know where I can find a couple of brass fittings to install mechanical water temp bulbs in the upper radiator hoses on a stock 1934? They seem a bit hard to find.
Thanks
petehoovie 10-13-2021 04:28 PM
Re: 1934 Radiator hose fittings
Talk to this guy > Robert Shewman, POB 163, Kimberton PA 19442 Tel. 610-933-6637 or email [email protected]
https://www.fordbarn.com/forum/attac...9&d=1602281392
mclark12 10-13-2021 06:44 PM
Thanks, I’ll contact him.
deuce lover 10-14-2021 12:44 AM
If you mean to connect an original dual-temp gauge- they are next to impossible to find.It been discussed here before.Last repo's made were in the 1980's.
koates 10-14-2021 01:16 AM
What some have done including me is to fit the later 1936 water pumps which have an inbuilt fitting in their body casting so that you can fit your temp sender in there and not in the hose. Some new pumps are available which have improved modern bearings and seals and improved impellers for better cooling. Check them out from Bob Drake, C&G Ford parts, Macs and some other dealers. Regards, Kevin.
V8COOPMAN 10-14-2021 01:54 AM
This Bob Shewman stuff ABOVE has nothing to do with bulb wells like the OP is referencing.
Click the link BELOW for quite a few examples of different thermostat bulb wells that are available. DD
https://www.bing.com/shop?q=temperat...75298F04F0DDB7
https://th.bing.com/th?id=OP.C5I7xAD...=1.25&pid=21.1
deuce lover 10-14-2021 03:37 AM
If he has the orig 33-34 dualtemp the nut at the bulb has female threads.It won't work in that port of the '35-'36 w/pump .An adapter will have to be made.
mclark12 10-14-2021 08:48 AM
Thanks for the feedback. More than likely I’ll have to install “36” pumps so I can install Stewart-Warner mechanical water temp gauges.
deuce lover 10-15-2021 07:34 AM
If you have or are using the original spark plug wire tubes - on the right side it might be a tight fit to install that sender.
koates 10-15-2021 07:39 AM
Nope, the sender will just fit into the right side pump. Its close. Regards, Kevin.
